Found it.
Asnes
1:35 PM
Windermere, FL, USA
I was going bonkers but not enough to deal with the issue until today….
There has been a metal on metal rattle / vibration since almost new but only at around 2,000 rpm and only under certain engine load conditions like accelerating in 8th gear on the highway…. Car has a little over 17,000 miles these past 1.5 years.
The rattle would intermittently go away, get louder, change frequency…. It would sound sometimes like a loose nut, but a nut that was slightly oversized for the bolt threads it was on, and would rattle / vibrate…
I tore things down today… I believe I have located the issue!
Going back out to drive and test :)
Video:
View: https://youtube.com/shorts/ooJ1d3DdmY4?si=cBYdvyJ4rn1Bje6J
Video:
If that's the fix I'd glue it back in place as a good luck token.
Video:
Hard to believe that was there by accident.
I wonder if they upsized the frites with their Royale with Cheese when they used your Grenadier for a Maccas run?
You found the golden shim...free visit to Jimmie Wonka's car factory 😃
