Factory roof rack bolts seized
10:31 PM
Derbyshire, UK
Has anybody else factory rhino roof rack bolts seized? impossible to get them out, having to drill them now unfortunately! Does anybody have better tips?
Regards
George
Regards
George
Did you try spraying them with WD40 or INOX and leave them overnight and try again?
Next time your screw them in, first coat the bolts with TefGel or something similar. Thread here on minimising corrosion, galling and seizing:
Regards
George
Which bolts? Did you try oiling and let them sit? For stuck fasteners I have had good luck with the 50/50 ATF/Acetone mixture. Or, oil then heat.
Upon receiving my Gren I removed all the bolts clamping the factory roof rack feet to the gutter and treated them with anti seize. I checked the tightness of every platform bolt too, but did not remove these.
My favorite is Kroil, the oil that creeps.
  • An industry proven penetrating oil that has no equal
  • Quickly loosens rusted nuts and bolts, frees frozen shafts, pulleys, etc.
  • Penetrates to 1 millionth inch spaces, dissolves rust, lubricates, cleans and prevents rust
  • Displaces moisture
Since I started using it, I have more friends. My hair is no longer thinning. I can speak Spanish. Attractive women half my age make eye contact again. Oh, and my nuts spin freely.
Send a link I need some of that elixir ASAP. 👍🏼
Sounds like those Spanish women will seize them again!
