Eyeglass/Sunglass Holder?
cdsvt
5:20 PM
Vermont, USA
Hi All,
I sometimes wear eyeglasses (night driving) and prescription sunglasses (sunny days), and am often struggling to find a place to put them.
A solution that works in my other rigs (sunglass holder on sun visor) doesn't work because I have Owl/Rosen sun visors and they are at cross purposes.
I'm currently using hard cases in the center console bin, but the bin is so tiny that the glasses cases eat up a lot of space so the bin is less useful for other items.
I'd love something that replaces or augments the blank panel on the overhead console, but it needs to be deep enough to hold glasses (ideally 2 pair).
Please share any options that you find useful.
Thanks,
Charlie
I have cut patches of stay put, marine non slip matting, same size as the small indentations both on the dash and infront of gear selectors. place my glasses on. not had an issue
Hi All,
Thanks,
Charlie
I had the same need so I bought the overhead shelf from Grenadier USA and used it to store a flashlight and the clear lens glasses I wear for driving at night. For my sunglasses that I wear most of the time, I got a cheap glasses case off Amazon that was compatible with the Molle System and hung it from the underside of the overhead shelf using its attached Velcro strap. The combo worls a treat as everything is right at hand when I need it.
All great ideas. Thank you. I like the range of options. The Greandier USA one would give me more general storage space and molle attachment options which would be a bonus. Looks like it comes in large and extra large - decisions, decisions. Thanks, all.
There is a perfect place to store a glasses case on top of the steering column surround if you have the steering wheel pulled out a bit. I have been using that for quite a while and the case stays put.
The idea was shared by another forum user.
I use a $10 clip stuck on with double sided tape below the safari window. Has worked perfect.
This - perfect spot, although occasionally gets a little hot in the sun.
Someone on here recommended this spot a while back and it’s a games changer! They don’t move and they’re right there. The only downside is you can forget they’re there. It’s the perfect size and doesn’t take room that something else would use.
I just put my sunnies in an organiser in front of the steering wheel, along with phone, pen etc.
Quick follow up: I went with the Grenadierusa overhead shelf in XL. It easily fits two pair of glasses with room to spare.
Two notes:
1) I am going to add some sort of rubber mat to prevent things from sliding out. There is a bungee cord, but it isn't super effective at retaining anything with a bit of mass (glasses in a case, for example).
2) The bin blocks visibility to the switches right in front of it (front and rear lockers, offroad mode, wading mode) Not much to be done about that issue. I don't love that, but it is a tradeoff- good in day to day, not so great offroad...
I suctioned cupped an elastic mesh to the sunroof and one can stuff a lot of shit up there. Cheap amazon stuff.
I set up a magnetized solution on the overhead panel:
Tested them today on washboard road and mild offroad track. Seem to hold up pretty well, and opened up a lot of space in the center console.
