EXT2 High Beam Trigger
acky
3:27 AM
Adelaide
Hi All,
Just wanted to share how you can get the lightbar on the roof wired to EXT2 to be switchable via the high beams.
this is a requirement in South Australia for any forward facing aux lights
Note, this was shared to me by a friend, Ken Amos (many thanks Ken!)
EXT2 on, lights on low beam, Lightbar off
EXT2 on, lights on high beam, Lightbar on
or
EXT2 off, lights on low beam, Lightbar off
EXT2 off, lights on high beam, Lightbar off
crude wiring diagram attached
heres a pic of everything as it sits in the Grenny
yellow wire is the trigger from the headlight, i made a simple piggy back loom from the back of the left hand headlight, you could probably use the Stedi Grenadier loom for this?
Hi All,
or
Great tip, thanks for sharing Ken's solution. This is a clever and compliant way to wire the lightbar.
For anyone else looking, the trick is using a standard automotive relay. Wire it so the high beam switch provides the trigger signal to the relay, and the EXT2 circuit provides the main power. This makes the lightbar dependent on both the high beams and the EXT2 switch being on.
It's exactly what I'm planning to do.
Is the yellow wire the same on diesel and petrol cars?
the yellow wire i added in
you need to make a piggy back for the back of the headlight
the headlights use 6 pin Deutsch plugs from memory, so make a small lead that extends this, then tap in to the high beam in this lead.
that way your not hacking into the vehicle loom
you could probably hack this up to make the lead
Just adding to this, as I am also fancying some additional lighting on my Grenadier...
On my motorcycles, I use the additional lights at LOW INTENSITY during the day (i.e. in DRL mode) - typically 25 or 30% brightness
You can then have them so that they come on with full beam at 100% brightness. It also makes wiring easier because the tech is in the controller (no need for wiring relays and fuses)
DialDim: https://uk.denalielectronics.com/products/dialdim™-lighting-controller-universal-fit
Skene: https://skenelights.com/skene-iq-275-intelligent-dimmer-for-led-lights.html
DialDim demo:
View: https://www.youtube.com/watch?v=qALMEJLZ6xs
Skene Demo
View: https://www.youtube.com/watch?v=008cgZ5Qpss
The Skene is much cheaper, but of course it is a less elegant solution. I did use Skene for a couple of years on my bike, but now upgraded to DialDim...
These solutions both seem to be marketed primarily at bikes, but no reason why you can't use them on a Grenadier
I notice that Lazer lamps now do a lightbar that has a obd2 dongle. I think it will use the old to read vehicle speed so that the lights move lower when travelling slowly and higher when traveling fast. I don't know if it reacts to dip as well but it would be a smart solution if so. Just plug in to the roof outlets and connect the dongle..
