ECU unavailable etc
scottyboy436
9:37 PM
scotland
Hello ,
This warning came on yesterday when the misses was driving the car , she turned it off and it cleared but it's back again this morning .
I'm assuming I will just need to phone the road side assistance
  • VID-20251105-WA0016.mp4
    1.7 MB
Hello ,
The electronic stability platform is off.
You can still drive it, but yes call the roadside assistance under warranty.
Another thing to check. Look at the rear passenger side, radius arm. The ABS wire may rub against the radius arm inner bolt. Best to zip tie it up. The insulation on my ABS wire was cracked, saved just it in time.
Shiitake has been doing this for months and had one attempt at solving but it returned shortly after. Sadly now I have permanent windscreen wipers on at the same time! Had to pull the fuse to drive into town.
I’ve checked my cages for stones but will also look at the ABS wires too - thanks for the suggestion 👍🏼
I’m considering doing a complete shutdown and restart to see if that might shake the problem? 🤷🏼‍♂️
Anyone else driving a Grenadier that expects constant rain? 🤣
Edit…
Sorry forgot to mention that after a chat with our actual Ineos Tech, he advised that the reduced brake performance is restricted to ABS so the brake system is still functioning but not 100% optimally! Nice for drivers to know this 👍🏼
Wipers not turning off is often a failed ECU in the dash - contact the dealer.
