ECU coding / cracking
RY-Journeyman
1:39 PM
Dunedin NZ
Hi fellow owners. One of the joys of my old Land Rover and also Range Rover, vw golf, and BMW X6 and X5s has been the ability to re-code the ECU. Not just plug in chips but software re-coding of the ECU. Almost every car I’ve owned in the last 15 years has had this done. Except my grenadier. Chip plug in boxes seems about the limit on that.
Does anyone know of an ecu coding company who does re-coding for the Ineos yet. In particular I’m interested in anyone who can re-code the car to switch off the service indicator reminder nags, reset the TPMS sensors etc. ie all things that we hoped Ineos would let us do ourselves when travelling to far flung places.
I know Pete Bell in UK was very good with anything Land Rover and I’ve just sent him an email to see if he’s had any luck with the grenadier yet. Will post when/if I get a response.
My other thought is to sponsor someone to make a bespoke product that can reset the service indicator as an ODB plug-in device. Anyone here that can do/make that or know of anyone smart enough to do it? Might be the hottest ticket item in the grenadier works shop if we can make it… Or better still persuade Ineos to do it as an official Ineos accessory that owners could purchase. I’d happily pay money for that and take it with me for remote travel.
There is a member on the forum that is diligently working on cracking the encryption on the engine DME for the B58, but definitely isn't there yet...
The service interval/TPMS are each separate modules, and would require someone to emulate the Bosch Grade-X scan tool.
Plenty of companies could do it, unfortunately the juice isn't really worth the squeeze given how niche and low volume the Grenadier is, at least at this point. A number of companies have been contacted, none of which are willing to put in the work required
The B58 DME has been cracked and can be benched. It’s the rest of the truck that’s the problem.
The version of the DME used in the Grenadier is completely different in regards to encryption and specifically map location as per several sources I've talked to
Sadly Pete Bell said he didn’t have anything in play currently. If anyone has any contacts in the relevant industry then I’d be keen to work with them to get a product to market - at the very least to allow the customer to reset the service indicator themselves.
Effort is not a function of how many features to unlock. Once you crack it, everything becomes available.
Just unlocking the service reminder toggle doesn’t make it a more trivial goal.
That's been my feedback as well...
The closest match seems to be a bespoke version of the Bosch line of diagnostic code readers.
ECU cracked
I am reliably informed the ECU has been cracked, as well as the Transmission. Dyno tests currently being done.
AU announcement coming around 1 Dec 2025. Various tunes will be available, towing, offroad, performance, etc.
Also Ad blue can be deleted for offroad use (diesel models).
Not at liberty to say anymore.
EDIT: GrenX now has the link up on its website.
ECU cracked
Hopefully they’ve cracked the service reset
ECU cracked
While you're communicating with the dark world @TheDocAUS, I and others have expressed a desire to be able to monitor the current DPF % soot loading value. Bonus points if a manual regeneration function could be implemented. If said crackers could pull this data out and make it accessible to the OBDII port then scantool and app providers could use it.
1. MONITORING. Display the realtime DPF soot loading value on an OBDII monitor such as Codebreaker or an app like Torque Pro. For this to be useful we would need to know the baseline value for regeneration. For example, if regeneration occurs at 50% and the current soot load is 30% there is 20% remaining until the next cycle. A toggle between current soot level and % remaining to next regen would be a nice feature.
2. MANUAL REGENERATION. Add a manual function so regeneration can be initiated early, maybe within 10% of default.
The automatic regeneration (burn) cycle operates without indications or warning and it can be disruptive to vehicle operations. An ability to monitor the current soot loading, or choose to start a regen cycle early gives choices to the operator.
If I'm on road, have at least 20 minutes left in my journey, and within 10% of the next regen cycle, I might choose to do it early instead of it happening automatically later which might be after I go off-road with dry grass and foliage hazards, or stop for fuel or lunch or an appointment and wait for the cycle to complete or be forced to leave the vehicle with the cooling fans still drawing heavily on the battery.
…or deferred, as the case may be. Particularly in regions where 50ppm is the go, and regens are therefore more frequent.
They were talking about tuning the motor, rather than adding features like this - which I really really want.
Understood. But if they're unlocking the DDE/DME they may be able to make the DDE soot value available from the OBDII port for other parties to access. It's a question about their capabilities and the architecture of the DDE. Or, just the process of unlocking the DDE might make this info available by default. Perhaps they could advise on that.
I thought hard about deferrals. My only concern would be contamination of the DPF that exceeds the ability for a regeneration alone to recover the DPF so you might quickly be heading towards limp mode and a workshop clean of the DPF.
It's been a long time since I read it, but I think there is a closed loop system in play here. If the regen doesn't get the expected result (reduced pressure differential after burn off) the DDE assumes a fault with the DPF.
Higher sulphur is hard to deal with. It makes sense why you see more regens. It's burning brown coal.
Also if you leave it too long and it does burn it may get so hot that it overheats….potential damage..
ECU cracked
If only thete was an app. Apps make the world go round.
ChimneySweep would be a good one.
It is now on GrenX website here about the forthcoming tunes. The post above was about GrenX:
Following - more interested in other aspects of the vehicle, infotainment, fuel bongs etc. but great to see some progress has been made in allowing us to modify coding/tuningsame
Same with me.
I am a customer for access, reading codes and resetting my own service light. Enhanced features would be amazing and will follow.
I rather like my TDI piggyback tuner for modest hp and torque gains and the fuel efficiency gained.
Great work!
