East TN Locksmith wishes to take measurements of Grenadier key and investigate immo system
3:47 AM
East Tennessee
Hi,
I am a locksmith that specializes in automotive, particularly the Euro stuff nobody else likes to mess with. Several months ago I spotted a Grenadier heading down I40 and it caught my eye, and have been fascinated with them ever since. I do a lot of work for the local Rover dealer and its customers, and absolutely understand the motivation behind building something with old Rover looks and capability but without the pitfalls of the current Rover reliability.
Anyway, there is absolutely no data available for how key programming is accomplished or what immobilizer system they use. There have been several questions raised in locksmith forums about the Grenadier, and believe it or not, a thread here has the most information I've found to date. Local Dodge dealer had one on their lot for sale, but it didn't last long and was gone literally hours before I could get down there to investigate.
If there is a Grenadier owner within an hour or two of Knoxville, would you be willing to let me take some measurements of your key in order to try and determine which DSD (depth and spacing dimension) it uses, or create one if it's truly unique to Ineos? This will involve measuring the key blade itself with a micrometer and running out some test keys. Most likely the volunteer will wind up with a spare key or two, although it will only be useful for unlocking the door, not starting the vehicle.
Furthermore I'd like to poke around a bit and at a minimum, plug in to the diagnostic port and see if I can identify any of the immobilizer components electronically, and if not, possibly (depending on how amicable the owner is) remove a few interior panels to try and determine the location and manufacturer of immo components.
I know the BMW driveline would suggest BMW immo components, but BMW has not used a keyed ignition since the late 2010's, and it did not use the chip type identified in another Grenadier key (4A).
Total time I'd need with the vehicle is about 2 hours. I can come to you at your home or work, and make the promise no testing will be done that would render the vehicle immobile.
If anyone nearby is interested, let me know either by PM or email, ben@lockmedic.com. Include the city you live in, and your preferred method of contact.
Thanks!
Ben Turner
Lock Medic llc
www.lockmedic.com
Hi,
Thanks!
Ben Turner
Lock Medic llc
www.lockmedic.com
You can buy your own key on ebay. there are several. I bought one a few months ago for $50.
everyone here has a few spare keys, from the door lock recall.
The dealer made me turn mine in. Are the keys even the same (the metal part)? I thought the locks themselves have different barrels. Maybe not.
WHat blade was cut (for your truck)?
How did you program it?
No I didn't get to that. I bought a BMW blank from AliExpress and I have to get to a locksmith or a kiosk.
[AI/ The INEOS Grenadier key fob uses different frequencies depending on the market: it uses 315 MHz in the US and other regions, and 433/434 MHz in Europe and other regions.]
Really? I thought we had the same dealer.
The new Freehold dealer (not RDS) did the work. They’re nearly and hour and a half closer and far less of a pain to get to.
Helpful, but the least costly one on there now is $100. There's a set of 2 keys with an ignition lock and what appears to be a hatch lock for $150, which is reasonable, but doesn't get me access to a vehicle to plug in and try and determine what immobilizer system it's using. I would be very surprised if it is bespoke for Ineos.
I know the chip type is 4A, but unfortunately that doesn't narrow it down to who built the immo system. That chip type is used by Kia, Hyundai, Fiat, Chrysler, Jeep, and a host of others I can't think of off the top of my head. Most of those OEM's manage access to the immo system with a static pin code that is VIN specific. Sometimes we can retrieve them from the module, sometimes we can't. The OEM's listed all participate with NASTF, so those pin codes are accessible to properly screened 3rd parties like myself, Ineos does not (yet).
If anyone here has an orphaned key (i.e. one for a Grenadier you no longer own, or your locks and keys were replaced for whatever reason and you happen to have an old key) they'd be willing to donate to the cause, or loan me by mail, that'll help me determine the DSD.
If you have a few moments, check out this thread as well, especially since you work on Rovers! I bet you’re familiar with potential lockouts that can happen in certain Rovers if a key fob gets locked inside the vehicle.
I have one I’ll give you, PM me your address if you want it. If I ever need a locksmith in TN I will have a friend.
