DVA Mechanics: Side Accessory Carrier, Gen 2
DVA Mechanics
Supporting Vendor
10:52 PM
Atlanta, GA, USA
DVA SideLock Rail System - Side Accessory Carrier for Ineos Grenadier, Gen 2​
Stronger. Sleeker. Smarter.
Take your Ineos Grenadier to the next level with our DVA SideLock Rail System - Side Accessory Carrier for Ineos Grenadier — our 2nd generation, redesigned from the ground up for increased strength, enhanced corrosion resistance, and a tighter, more aerodynamic profile.
This versatile mounting system creates a seamless bridge from the roof cargo rail down to the side-mounted L-track tool belt, giving you a robust and modular platform for attaching mission-critical gear—Jerry Cans, Molle panels, recovery tools, and more.
Compared to Gen 1, the Gen 2 rail sits closer to the vehicle body for improved aerodynamics and a streamlined silhouette that complements the Grenadier’s rugged styling. Built from upgraded black anodized aluminum, it’s engineered to perform under punishing conditions while resisting the elements far longer.
Whether you’re heading off-grid or need additional utility for daily use, this system offers a rock-solid solution—without compromise.
Find it here: Side Accessory Carrier Gen 2
1 Side_Accessory_v2_DSC00062 Medium.jpeg5 Side_Accessory_v2_DSC00022 Medium.jpeg7 Side_Accessory_v2_DSC00045 Medium.jpeg
Upgraded Gen 2 Design: Reinforced structure and improved corrosion resistance over Gen 1
Tighter Fit: Sits closer to the vehicle body for a lower profile and better airflow
Parts Included: Custom roof bracket, accessory strip, L-track lug/bolt
Vehicle-Specific Fit: Precision-made for the Ineos Grenadier—no drilling or guesswork
Universal Mounting: Supports Jerry Cans, Molle Panels, tool mounts, and more
Black Anodized Aluminum: Lightweight, durable, and built to handle real-world abuse
Load Capacity: Rated to hold up to 25 lbs per rail
Note: Accessories shown (Jerry Can Mount, Fire Extinguisher, etc.) are not included and are for demonstration purposes only.
Can you actually mount jerry cans to these, though? Your weight rating is 25 pounds per rail (two required to mount the jerry can holder), so 50 pounds. How much is the jerry can holder-- keeping in mind a metal jerry can is about 9 pounds, with 40-50 pounds added in the 20l of fuel? Is that why I haven't seen any photos of a side-mounted jerry can on your website?
