DVA Mechanics roof rails with Roof Top Tent and Awning
Geoffilmuro
12:50 PM
Hi, Has anyone tried the DVA Mechanics Roof Rails with a RTT? Tent is ARB Esperance (57Kg) and Awning is Latitute Wingman 270+ (29Kg). Have asked DVA and they said Static weight (including my wife and myself) is close to limit for the rails (but should be okay) and Dynamic weight is fine. Not sure whether it is possible to get under the roof rails to attach the tent and whether the awning will fit. Interested in other suggestions for the roof rails too but like these as they are low profile and look pretty tidy.
Might be worth speaking to Tom at Overbuilt UK. He was a technician at Carlisle dealership and set up on his own as he was too good and interested in the vehicle to stay as an employee. He did some bits on mine when he worked at the dealer. He deals with DVA and imports their stuff so will be very knowledgeable.
Overbuilt UK — Overland Builds & Vehicle Solutions https://share.google/vRuOnRpQeE1TLvMwU
Upvote 0
Thanks - that's useful. I have ordered the DVA rails so will send some pics once all mounted. Useful to have the contact for Tom as also looking for a leisure battery for the fridge etc.
Reactions: CRH
Upvote 0
He sorted me out with fitting and sourcing the leisure battery for my fridge.
Upvote 0
I have DVA racks but no RTT on the Grenadier. I assume there are brackets that fits to the rails and the RTT attaches to those? If so, take a look at using the DVA L-track bolts which are M8 and come in three different lengths. I use those for my shovel mount and M6 L-track sliders for my Hi-Lift. I had to adjust the length of the bolts for the slider attachment while the track bolts were easier to use (I use the 20mm length version.). Also, with weight on the rails the center can come into contact with the raised part of the IG roof. I've put some adhesive-backed foam pads attached to the bottom of the rails to prevent metal to metal contact.
Upvote 0
Thanks. That’s a good idea on the foam pads. I think the tent has brackets that clamp round the roof bars. Might leave it a bit tight between the bracket and the roof. Be good to have something which stays above the rails so will look at the L track bolts. Still waiting for tent to arrive so I can see how it all fits together.
Upvote 0
Maybe I am misunderstanding but are you saying that the rails are bending in even with static flat tent floor?
Upvote 0
@OkGo - No - they bend a bit individually when you’re close to their stated load. Like when I’m standing on them. I don’t think they would flex at all with a properly distributed load like the tent. The foam I put on is strictly for the first scenario as the roof is a great place for landscape photography. I’m very happy with their quality and specs.
Upvote 0
The ARB RTT doesn't fit as the RTT brackets are made for thicker bars than the DVA ones and the awning doesn't fit as the brackets are made for narrower bars than the DVA ones. I have ordered the DVA awning brackets - so that should sort the awning. For the RTT, I am looking for some brackets that can clamp around the roof bars that have a U that is around 10-15mm in depth. Anyone seen them for sale separately? I can get them made but easier to buy if I can find them.
Upvote 0
