DTE PedalBox Pro
chrsbe
4:57 AM
Sternwartestraße, Wien, Österreich
Does anyone have experience with this product?
How difficult was the installation?
Is the throttle response more direct in high range?
I’d actually like a less sensitive throttle in low range. is that possible with this?
Can I customize the throttle curve myself in the app?
Easy to install, it does improve or reduce the response. The eco setting can make it a slower or sports options increase. There are options to increase and decrease in 3 incremental positions either way in each of the set options.
Not sure you would be able to adjust other than the above.
The set options are
Eco
City
Sport
Sport +
A must have for the Grenadier from my point of view. Installed 2.5 years ago and happy as can be.
Eco for daily driving and better (faster) response of the gas pedal.
Besides the above mentioned there is also a „Low mode“ which, combined the low range of the Grenadier enables you to drive to the milimeter.
Also you have an extra level of protection by disabling the gas pedal completely in the app.
The install is done in 2 minutes, plug and play.
I have both the tuning box and the pedal box. The tuning box set off the check engine light numerous times. Not sure why but I ended up taking it off. An expensive purchase that did work in fact but drove me crazy with error messages. The pedal box works like a charm. I still have that thing installed and I agree that it makes the throttle MUCH more responsive in the Sport and Sport+ modes. I like the gradient settings because the throttle can get overly sensitive unless you have a very steady foot. Would definitely purchase again.
