Design Build Go - ARB onboard compressor installation on YouTube
I have made an enquiry and now await a reply. If they can make it work I’ll be getting one 👍🏼
ARB. have UK headquarters in the mids
Ok thanks. Maybe I contact them to come up with a mounting solution for under the Grenadier seat. 👍🏼
Edit. Inquiry sent to ARB
Check this out for a twin ARB compressor mount under a front seat from OWL. . A really neat easy fit solution. This is the compressor mount solution that I’m most keen on so far. 😍
View: https://youtu.be/PwdVlo_jmuo?si=BzuDjXUqwqrCIifC
Interesting solution from Owl, even for a "single" compressor.
Indeed a "pain in the ass" when mounting it under the rear seat (what I did, see my post here).
But the ARB compressor works as a charm. And indeed as the OWL guy says, much better to mount the compressor "inside" the car!
For my needs, a single compressor is OK.
Yeah I’m kinda liking the idea of that underseat twin mount. I was thinking of doing the spare mount ARB twin with the NATO harness and bracket from Blacksheep. I still think that’s awesome, but I ordered winter wheels and tires, and that winter wheel spare won’t take the Grenadier spare storage box. Not like I really need to be airing down for off-roading in winter, but it would just be one more thing I have to move every season. With the Owl underseat mount, I can just forget about it until I need it. I’ll put it on the “futures list” (which will now take me about 3 years to work through - each step has to be inconspicuous and spaced out so my wife doesn’t notice).
I've send an email this morning to OWL asking if they're planning on releasing another bracket for the passenger side too. I'll post their reply in here for you all to read.
“Hey Henrik,
Reece here from Owl. Thanks for reaching out! We are short staffed in the office right now so I really apologize for the delayed response.
We are going to be coming out with a RHD version of the compressor mount, we just haven't released it yet. Stay tuned, we should have it in the next two months or so!
Thanks!
-Reece
“Hey Henrik,
Thanks!
-Reece
I’ve just received the same reply from Reece at Owl after enquiring about a right hand drive version.
Looking forward to fitting my compressor later in the year 😍
I love all of the creative options vendors are coming up with for mounting compressors. I'm having a hard time making a final decision, because there are pros and cons to the various solutions. The under seat idea looks all Kool and the Gang, but I also wonder about heat from the compressor negatively affecting other wiring, etc. under there or the compressor itself overheating. What if you want to wash out the floorboard or a water crossing gets a bit too damp for comfort? In any event, I thought it might facilitate discussion to include ARB's list of factors to keep in mind when considering where to mount it:
I particularly like number 14 - "The compressor should not be mounted in a position where the running sound might be considered startling or irritating for vehicle occupants." I can see my wife's face now sitting in the passenger seat when I am airing tires back up: :mad:. She would no doubt shout something at me, and I would just yell back, "What?! I can't hear you!" Hmm . . .
Is that a feature or a bug?
Trying to figure out the best place to put this, and this thread looked like the right spot before all the Owl talk! I’m new here so LMK if it should go somewhere else.
I installed the Agile one today <pats himself on the back>. I’m mechanically inclined but this is definitely the most invasive thing I’ve ever done to a brand new car (delivered last week)! But the kit was amazing - everything was just right and the instructions were perfect. I hadn’t seen the OPs video, which would have been great also…. So thanks Agile for a nice kit that a rookie could handle installing.
So, I installed the compressor under the seat yesterday. After having disconnected the positive lug on the battery, I now have warnings that the front and rear differentials are on and the AEB is off. Any suggestions?
Not really, but some warnings disappear after some hours driving. For instance I had an "orange warning" on tire pressure some days ago. I used - of course - my compressor to put some air in the tire, and only the next day the warning was gone!
Did you wait 15 minutes or so after taking key out of ignition before disconnecting the battery to attach the power supply for the compressor? I fitted my ARB under seat compressor a few weeks back and no problems apart from a few warning lights on after initial start up. These soon disappear after a few minutes driving. The only light that stays on after battery disconnect I find is the passenger airbag is turned off and a warning light is on for that. The procedure for turning the passenger airbag on and off is in the owners manual.
I had a similar situation, I removed the fuse for the wipers so I could change the rear blade without removing the rear tyre.
I then had an orange warning saying wiper fault which didn't clear by itself. No actual fault.
I disconnected a battery terminal, pressed the horn and brake pedal to discharge everything. Error message was gone.
Yeah, per the recommendation of an Ineos sales guy, I drove the truck for a bit and the errors went away.🙄
The key had not been in the ignition for hours. After driving for a bit, errors disappeared.
Did you connect the positive to the main battery or to the secondary battery if equipped with one? I’m currently connected to the main battery but, my brother said I should connect it to the secondary battery instead. Thoughts?
I just disconnected the -ve on the main battery.
Latest posts
