CTEK SMARTPASS 120S and 250SE DC to DC charger basic features and install information
Dear all!
INEOS Germany has just rejected a warranty claim from me for a CTEK 120S because an INEOS service partner installed a CTEK 250 SE. This means that changes have been made to the installation and the warranty has expired. INEOS is also of the opinion that defective LED displays on the CTEK 120S are not a defect as long as the service battery is still charged. One can only marvel at this...
Cheers.
SMART BATTERY CHARGERS
In depth video from @Red pepper on chargers, with two CTEK experts. Not directly on the 120S or 250SE but great information regardless.
View: https://youtu.be/8xTWkOpDNWE
Thanks for the above. I'm "late to the party" but I found the interview most instructive in terms of the exact function of the second battery and the Ctek120S and what I'd refer to as the "Ctek philosophy" which I hadn't fully appreciated until now. It certainly hasn't been properly explained either by Ineos nor Ctek to date in terms of the Grenadier application.
My uninformed complaint was that the system was not as I had expected in terms of a dual battery arrangement!
My "education" came around the 26 minute mark in the video: essentially the pulse charging of the main battery by the second battery is a form of conditioning which reduces the likelihood of sulphation and amongst other things, where there vehicle has been left standing, keeps the electrolyte from developing layers of non-uniform acid concentration.
Conclusion (mine): The Ineos system has been designed to optimise the life of the (expensive) EFB Molle Stop/start battery, and is best left well alone. Use a separate setup with a DC-DC charger to maintain additional "house" batteries for accessories ...fridges, camp lights etc ....
In the past 9m for various reasons, I've driven less than 1,500km in my Grenadier since the first 12m/15,000 km service, but I have charged the batteries every couple of weeks using a Victron 15Amp IP65 intelligent charger. Seems that based on the tech. explanation in the video, reducing the interval to once a week to bring the system to float/maintenance mode would be an optimal course of action. (One of the Ctek interviewees uses the example of his 2019 Audi which he implied is "hungry" in terms of power demands, is still on the original battery (Feb2025) because he keeps it regularly charged to float (100%) level , whereas the alternator alone will never reach much more than 90% in day to day use.)
Thanks again @TheDocAUS for drawing attention to this info. IMHO it goes a long way to explaining the design philosophy of the second battery arrangement in conjunction with the Ctek 120S.
Denis
Thanks for the feedback.
I added that video to my list, as others will benefit from looking at it. Your comments highlight to me how important it is - but I have some experience with smart chargers, so I "missed" some of its importance. Thank you.
And big thanks to Robert Pepper.
INEOS CONSOLE
And people can better understand the Console feedback on charging volts and amps.
Thanks @TheDocAUS for the original past and @DenisM for your summary. When i get a spare hour in the day I'll watch video and update the manual as needed.
Cheers
Steve
After this video I attached the main battery to a 7 stage BMPRO 15 amp charger (Proifle set to AGM and charge rate 15 amps). Bulk charge only took a few minutes before it swapped to absorption. Absorption was somewhere between 45 and 60 minutes and the final steps quickly followed.
It seems my OEM dual battery setup 120S (mated with a 250SE and a rooftop solar panel) does a good job keeping the batteries in shape. That solar panel covers any small or parasitic draws and can top up the aux and the main battery over the day with enough sunlight (I can see this using my battery monitor software).
Hi All, just finished reading this thread, lots of great info! however...
I have the 250SE fitted by Expedition HQ in Australia, i have just gone through some pain trying to get the right solar panel delivered to me from a supplier in Australia
both time they have sent me the wrong panel (OCV 27v! )
so im now stuck with two incompatible panels for the 250SE
im now planning on a Victron MPPT and connecting it either directly to the Aux battery or starter battery
i would prefer to connect it to the aux battery and it does trickle charge back to the starter, am i correct in thinking this?
ive also read i could connect the panel to a mppt then directly to the 250SE, the logic being the mppt will handle the OCV over voltage, would this indeed work?
Assuming all your loads draw off the starter battery I'd connect the Victron regulator to it rather than the Auxiliary. Provided the output voltage from the victron is above 13.1v the smartpass should connect to the auxiliary battery and start charging it as well. The trickle charging function from the auxilary is only enough to compensate for self discharge of the starter battery, not recharge it.
I've set up a fused anderson plug pigtail to my starter battery so I can plug in either my victron solar regulator or my battery box DCDC charger. If you do this make sure that you attach the negative cable to an earth point (eg the one at the base of the seat next to the main fuse box) and not directly to the battery so the vehicle battery management system can register the charge going in.
Cheers
Steve
Cheers
Steve
Thanks Dr,
I have all my loads connected to the Aux, UHF and an Anderson wired to Aux positive and the earthing point for the fridge in the rear.
the only thing that runs off the starter would be the Starlink mini, via a roof plug, this is only when driving, if im in camp for longer than a day then its plugged into a lithium pack
thanks! this will be the cheaper option!!
Sorry, finger problems on phone and I accidentally deleted the original message.
The good news is you have two panels for the price of one😄
Run the panels in parallel for double the current.... !
Power diodes from my quick search (similar issue) typically consume about 0.6V - 0.7V.
To provide some margin of certainty from 27V down to less than 22.5V, then 8 diodes connected in series on a heat sink would account for between 4.8V and 5.6V. Given a +/- 10% variation in the diode rating this should comfortably accommodate your needs.
Alternator diodes come to mind as heavy duty items to accommodate double the current from two panels but I don't know whether their characteristics would suit your needs.
Can you let us know when you solve this?
thinking about this some more,
i think it will be easier to connect a MPPT (Victron) to the Aux battery and plug the panel (on the roof) to this
the rear solar input as fitted by Expedition HQ runs to the 250se, i will leave in place for additional inputs if i ever need it
will do some testing to see if the solar connected to the aux battery will pass charge to the starter, i assume it will but at a reduced rate
I just want to run the fridge if camped for a few days and keep the batteries topped up to reduce the affect of opening doors etc draining the start battery
Still learning.
Use case - Dometic CF50 connected to service battery (since the damn consumer has been removed) and want to use a panel(s) with over 23 open circuit volts - does the MPPT go to the service battery or to the CTEK 250SE?
Since I don't have room on the roof, adding a Lensunsolar to the hood to go to the CTEK 250SE and then eventually get something bigger, more powerful if I need it, hence the secondary MPPT.
The solar panel is connected to the CTEK250SE solar inputs.
Power from the solar panel charges the aux battery first. Once that is charged, it can trickle charge the main battery. I assuming the 120S and 250SE are joined by the CTEK bars.
I connect my fridge to the aux battery, the battery getting most charge from the solar input.
I want to add a solar panel to support the fridge this Summer. I do not currently have the 250SE, so is this a better solution than running the MPPT to the service battery?
The challenge with the 250SE is you are limited to panels under 23 open circuit volts.
