Cracking noise coming from the rear door :-(
inky_black
3:29 PM
Deutschland
I've had a cracking noise coming from the rear door for a few weeks now. This weekend I started troubleshooting and removed all the attachments.
Yesterday I had help with troubleshooting.
While driving it continues to crack, my help then pressed against the door with his legs and the cracking stopped.
Has anyone experienced this before and does anyone have a solution?
  • Sad
Reactions: IGL
Heard "noises" from the rear door area and discovered that the plate which anchors the gas strut to the cargo floor was loose! Tightening the plate fasteners cured the noise. Check also the door latches and whether they need to be adjusted to provide more compression on the door seals when closed....
Thank you very much @DenisM , I looked for it, unfortunately it wasn't. It still makes a noise.
@IGL This is not so easy to identify. The pressure was exerted on the separating point of both doors. Then it was quieter during the ride.
Do you have any other ideas?
Update: The error has been fixed. See text.
We went for a test drive and pressed the doors while driving, the noise was gone while the pressure was being exerted on the door.
My Ineos is currently being serviced and the problem has been fixed by readjusting the door. I got a new rear door seal not too long ago. The new seal meant that the door only ever latched in the first position of the lock but not in the second fully closed position. I did not notice this immediately after replacing the seal because the new seal had not yet settled. In the meantime, the new seal had settled and the door was always in the first position of the lock and had play, the door was virtually never closed properly. Now the lock catches have been readjusted and the door closes completely again, the cracking while driving has been eliminated.
Best regards,
Inky Black
Update February 2025: Problem has reappeared, Ineos has not found a solution for months
The noises reappeared at the end of the year and I went to my trusted workshop to carry out intensive troubleshooting. The noise has gotten worse and worse. It occurs during normal driving with the slightest twisting of the bodywork. In fact, it comes from the large rear door and can also be reconstructed by exerting pressure when stationary. The current assumption is that it is due to defective welding points on the rear door. I and my garage have already been in discussions with Ineos for nearly 3 months to finally obtain approval for a door replacement. Ineos is currently refusing to comply and is demanding that my agent carry out extensive investigations in their workshop. The customer is suffering from the problem and the lengthy processes at Ineos. It is not yet possible to estimate how long it will take until a door can be delivered. It is frightening that no stock is available and it is not clear when it will finally be available again. I am curious to see when this problem will finally be solved.
Keep your fingers crossed.
Best regards,
Inky Black
Update in April 2025: Ineos does not supply spare parts, cracking gets worse with rising temperatures
You can hear the cracking in the following video. It's very unpleasant and certainly can't be dismissed as normal. Of our three Grenadiers in the family, only I have the problem with the cracking. The cracking occurs particularly during load changes, e.g. when accelerating and braking. But also when the body twists during normal driving. The door is made of aluminum and the welding rivets are made of steel, we know that this pairing does not get along very well.
There is currently no update on when the new door will be available. I have already been told several times that Ineos is having massive problems supplying replacement parts. This doesn't make me particularly happy and something definitely needs to change here.
Is it a petrol or diesel ⛽️? Internal or external, can it possibly be from the exhaust, I'm thinking a defect in the silencer echoing in the back
It is a faulty spot weld, we discovered this in the workshop (@Eric It is a diesel).
The cracking can be reproduced by applying pressure to the locks on the large rear door from above and below. It is also sufficient to simply press with your hands. Then you can feel a movement of the sheet metal in the middle of the door, at the welding rivets above the door opener. Ineos has also accepted this diagnosis from my workshop and will pay for the repair, but unfortunately no progress is being made. Because the internal Ineos processes are so lengthy and above all because Ineos has no parts available. The supply of spare parts from Ineos lags at every turn.
Update in May 2025: a new door has been installed and the noises are no longer present.
In the meantime, I have had some e-mail correspondence and phone calls with Ineos regarding fixing the cracking of the rear door.
Since there were still no replacement parts, they have now removed a rear door from a black display vehicle from Ineos and installed it in my vehicle.
This was the quickest solution for me without any further waiting time. I am glad that it has finally been fixed. However, the sad thing is that I had to phone almost every day to finally get this result. Ineos currently has major problems with the availability of spare parts beyond those needed for service.
In the end, it was worth sticking with it, looking closely and listening to your gut feeling, finally no more cracking while driving.
Best regards,
Inky Black
I have the same exact problem. 100% the same cracking noise that also gets worse with body roll. Disassembled everything looking for bolt or clip that fell out, but nothing. Started after a recent very long road trip. Are there any pictures of the failed spot weld?
Unfortunately I don't have any pictures of it as it was not visible from the outside @clm7214 . Ineos tried it three times with endoscope cameras. In my case it was the welding points approximately in the middle of the door under the rubber block.
When the door was squeezed/compressed, the noise could be reproduced and vibrations could be felt at the broken spot welds. You have to be two people to do this. One person compresses the door, which works best if you apply force to the top and bottom locks. The door also experiences this force while driving, e.g. due to body twisting. the second person feels the welding points while reproducing the noise.
I chose this picture for better visibility. My grenadier is actually black.
Best regards,
Inky Black
Best regards,
Inky Black
Thanks. That really helps.
