Costco Dometic CDF50 dual zone cooler/freezer
Has anyone tried out the Dometic dual zone cooler on sale at Costco right now? Link below. Thoughts/comments/reviews?
I have the CFF70DZ in my Lifestyle hybrid camper. The CFF series doesn’t have the Bluetooth remote monitoring feature that the more popular CFX series has. Other than that I believe they’re much the same in function and performance. I have been using this one in dual mode for 5 years. The only niggle I had was a cutout issue which took me a little while to figure out was the low battery protection system. Once I reset the cutoff level it was sorted.
This one lives a sheltered life on a pullout slide on my camper but at times it’s got wet, dusty, and operated in full sun in hot weather (36c/97f). It’s been solid. I’d buy again.
Reactions: CRH
My Dometic just stopped working yesterday. Wouldn't turn on with the 12v socket, just had some faint orange light flash in the power light. Tried the inverter and it came on but 2min later made a beep and cut out. Both 12v and inverter are running off the same battery and power was showing at 98%.
Any ideas?
Any ideas?
I guess you checked the fuses etc? My waeco has a fuse on each feed, behind the socket that needs some disassembly to get to
Fuse panel under the steering wheel its either something like 19 or 21 check those fuses there.
