General Coolant hose protection from chafing
C-Mack
9:01 AM
Utah, USA
After getting to know my Grenadier a bit more and inspecting in the engine compartment (petrol version), I’ve noticed a few coolant hoses run very close to sharp edges or other components which over time with vibration and heat expansion could cause a hose to chafe and leak. I’ve also noticed hose routings in some parts of the engine compartment, especially between main radiator fan shroud and engine front face have a bit of a prototype look to them and are being held in place by what look like non-factory zip-ties in odd locations. Could it be pre-delivery remediation by the dealers after Ineos has noticed a production issue?
Just for piece of mind in a few locations I decided to cover the hoses with a protective wrap. I ran across a product called Dura Wrap (can be cut to any length you need) and it is available in a few different sizes. The hoses I was most concerned about were the 1” (25mm) ones which seem to run everywhere in the engine compartment and put wrap around spots where chafing was likely to occur especially with the added vibration encountered off-road. I can’t see that it will hurt anything to have a little added protection in spots so here is a link to the wrap I used and a few pictures of it installed if anyone is interested.
I also fitted some wear protection mostly on the smaller lines. I then created a few makeshift supports from heavy zip ties for sections of hose that seemed too little supported but didn't require flexibility to function. I use three ties to do this - one zip tie around a stationary part (or nearby hose), another around the loose/floppy hose or line, and a third joining them together. There are some coolant line connections that make no sense to me and are in very difficult-to-service places so I rotated any hose clamps into accessible positions so I can remove them in the future without a prehensile tail or three hands.
You should make and market a kit.
Confuse/injure hundreds of greying end users 😄
I don't expect Ineos to do much until it's demonstrated that there is an issue. I'm okay with the aftermarket going above and beyond for extra protection.
Better support for some of the big floppy hoses would be a good starting point on Ineos' end. It's not like there's much movement between the engine block and the steel girders they call a "frame".
There is an additional problem with the coolant hose connectors. I’ve just hit 9400 miles on my MY23 petrol grenadier and had a failure of one of the coolant hose connectors. Looks like the plastic connecter has degraded ( it appears the plastic has turned to a soft powdery texture and the connector just snapped.) Coolant spraying all over the place, luckily I was only on a short trip near home. I’m now waiting for the next connector to fail. Dealer said he’s never had to fix a problem with the coolant hose connectors. I requested a replacement with a metal connector but they want to exchange it with another plastic one. Hmmmm….WTF .
Hmm, very interesting failure there. I wonder if the piece was originally fractured, bent over or cracked during assembly and the subsequent heat cycles and hot coolant got into the fracture further degrading it? Seems odd only one side of the fitting degraded but it could just simply be a defective part from new.
Bit late to this problem as my grenadier decided to leak all its coolant out today. 4 hours on the road side and trailered off to the dealers. Looks quite simple to me, both ends of hose, plastic connectors disintegrated as in pictures. Have they not changed these for metal yet?
Are these INEOS specific fittings or are they part of the BMW motor package? Do we know?
I would expect maybe not, the hoses are made in England as the sticker. I cannot believe that these cheap flimsy plastic connectors are meant to survive for long under these pressures and temperatures with a plier clip holding the joints in place. I am sure all these hoses will be completely redesigned in a newer version.
Just a footnote, I noticed an hour earlier my heater beginning to fail, feels like this poor water circulation and bore degradation is causing many problems!
Plier clips survived in my Nissan Patrol long term over many, many corrugation and difficult roads, the plastic connectors are the main weak point. That damage is concerning.
People forget Toyota went through years of mining workshop repairs to toughen up the Landcruiser. It will take years for INEOS as well.
Perhaps the aftermarket can print a set of some more durable clips?
Same exact failure on mine.
Luckily, failed on a 1 mile trip to the grocery. I only noticed when I got home and opened the door. Immediately smelled coolant and it was pouring from under the car.
Mine was a plastic fitting that spliced 2 small hoses together that went from the engine to the high temp reservoir.
I bought a brass male/male barbed fitting to fix it because my dealer is 5.5 hours away.
When handling the hose to put the brass fitting in, the plastic fitting on the other end of the hose (where it goes into the engine) broke.
It too was trashed. Degraded/chewed up looking.
I couldn't field repair that end of the hose, so I loaded the Grenadier on my trailer and hauled it in where they fixed it under warranty.
P.S. Tow coverage included 100 miles. The tow company quoted me almost $2k to take it the remaining 200.
We need to work up a kit of field spares to fix these issues.
We need to work a kit of field spares to fix these issues.
And the saying , two is one and one is none.
The moment you realise you used the connector for some other project or for a friend's car.
Double up!
It's certainly worthwhile getting under the engine with a headlight and checking all hoses/clips as a baseline and - if inclined - each time you check the CV boot.
