- Local time
- 9:16 PM
- Joined
- Oct 2, 2023
- Messages
- 524
Antonio,
The fronts are linear, 200 lbs/in. The rear is progressive, 200-256-428 lbs/in
- Team Eibach
To match the above chart, this means the Eibach 1.7F/1.2R kit has spring rates of 35N/mm in the front and 35/45/75 N/mm in the rear. This means they are slightly stiffer in rate than any of the OEM optionsGot this from Eibach regarding the lift springs 1.7 front and 1.2 rear.
Antonio,
- Team Eibach
This is an absolute factThe Ineos black springs are seriously expensive....
That is what i meant by assume. We have the deflection at those two weights. What if you add 400 pounds The rears they have are progressive for all the other lines so i would assume these are as well. So can’t really calculate but i think it probably does not matter. You know it will between those two numbersYou can calculate the spring rate from the description. First, this 1000lb rear set (and the 500lb rear set E30-34-001-06-02) assume that 200-400lbs has been added to the base weight of the vehicle (skid plates, rock sliders, rack, roof top tent, etc.). With no more load, the rear lifts 2.8” (2.4” for the 500lb version). Then, if you add 1000lbs (cargo, trailer tongue weight, etc.) the rear sags to a 1.4” lift (same 1.4” for the 500lb version).
For the 1000lb set, adding 1000lbs to two springs drops the rear from 2.8” to 1.4”; or 1000lb / 2 springs / 1.4” sag = 500/1.4” = 357lbs/in (likely 350lbs/in) spring rate (assuming that they are linear springs). For the 500lb set… 500lb / 2 springs / 1” sag = 250/1” = 250lbs/in spring rate.
Searching for similar Eibach springs rates of 350 and 250 yields results for many of their products.
I sort of assume all the aftermarket springs would be stiffer but you know what they say about assume.To match the above chart, this means the Eibach 1.7F/1.2R kit has spring rates of 35N/mm in the front and 35/45/75 N/mm in the rear. This means they are slightly stiffer in rate than any of the OEM options
I'm thinking the exact same way. The only hesitation I have is the drive shaft issue. But then again I'm at 10k miles without any problem and 1.7" is a very small lift.Problem is if you are not fully loaded it will be very stiff. Like an empty pickup truck. Bit of you have a lot of weight already maybe this will work. My weight is occasional so the airbag might be an idea. I could do the 1.7 lift and see how it behaves adding airbags if needed. I think that would handle the winch and a future bull bar as well as rack and other odds and ends. Might be lugging some extra fuel.
This is where a good progressive spring comes in. The lighter rate provides some utility in a near empty vehicle.I'm thinking the exact same way. The only hesitation I have is the drive shaft issue. But then again I'm at 10k miles without any problem and 1.7" is a very small lift.
I think I’ll be looking at the black marked springs once I get the lifting roof conversion and the auxiliary fuel tank fitted. Already my Grenadier seems to sit lower than other Grenadiers when parked next to them.When I enquired the black were same price as the other ones. About£100 each.
Here in the US the black rear springs sell for £325/eachWhen I enquired the black were same price as the other ones. About£100 each.
Maybe @anand knows better but I believe Eibach USA makes the springs for the USA. This might be the difference in price.Wtf!
I hope my dealer hasn’t miss quoted me.
From what I was told all the OEM springs originate outside the US. When I first inquired about pricing sometime around the middle of last year, I was quoted around $150/ea for the springs. When it came time to order in February of this year, the pricing had changed drasticallyMaybe @anand knows better but I believe Eibach USA makes the springs for the USA. This might be the difference in price.
