Coil spring air suspension
Great. That’s the same as I’ve ordered
How are they when empty and alternately when full loaded. What pressures are you using.
With 260kg tow ball weight running 45psi. Rides with a lot more confidence, and level with van. When empty I leave about 20psi to keep shape. have Engle fridge, double draws and kelpie in the back
I'm at 230/40/15psi
Hi Tazzieman
Where did you get the air valves fitted. I am fitting the airbags myself. Thanks in advance
Just below the rear bumper
@GrenX to get the valves to that location what level of disassembly is needed? The whole rear bumper off?
Thanks,
Steve
I'm not GrenX but I installed mine. Simple answer is no, you can reach that location either by pushing the bumper material (plastic) down or from behind in the wheel well. No disassembly required.
Thanks,
Steve
This is correct you don't need to remove the bar to fit the valves, its easy and protected location from mud and dust. We have fitted some for clients where the petrol filler is but its more complicated install so I prefer the bar location.
I know it's been a minute since this thread was updated. Anyonw in the US care you give a review of the bags?
I found that I'm now roughly at 800lbs additional weight on my car. Underbody armor. Roof rack, awning, drawers, tools and steel skid plates.
I'm wondering if I would benefit from air bags. Looking for feedback and reviews.
Also...
@GrenX do you have install instructions for your airbags?
Trying to decide how much of effort it is.
What is the main difference between your kit and the airbag man kit?
I'm the guy from California that stopped by your place in Melbourne last November.
If that extra weight is going to be constant which in my view it will be, then Eibach spring upgrade would be my choice. Air bags IMO come into their own with trailer and caravan towing that is not constant.
Uprated suspension springs
https://www.theineosforum.com › threads › uprated-sus...
26 Feb 2025 — The Extra Heavy Duty (XHD) Eibach springs – Minimum constant load 300kg, are pretty beefie...is it ball weight or just a constant load you are ...
I got this article yesterday via the newsletter of a fairly respected Australian 4WD adventurer and educator - Pat Callinan. It's on point for a sidebar discussion about airbags.
The info is supplied by an Aussie company called Airbagman which @parb noted above. They do a few different Grenadier kits with or without high pressure sleeves for high pressure applications (higher loads) and for standard height or raised suspension. Details here.
GrenX supply Polyair kits. Different brand of components.
Market choice is healthy👍
Reactions: Max
Latest posts
