Clunk when slowing down
This is a very basic summary, ZF 8HP has a well packaged compact design and would have one of the most complex gear flows to explain. Looking at an 8HP gear sequencing changing from from 3rd to 2nd the transmission is going from one brake and two clutches in 3rd to 2 brakes and one clutch in second, using euro transmission terminology. US terms a brake as a holding clutch holding generally the planetary ring gear but may hold another planetary element to the transmission case whereas the clutch holds two rotating elements together. During a coast to stop the transmission line pressure (main pressure) will be near the lowest pressure to allow for a softer slower shift. A sudden throttle up during the shift will be detected quickly by the software with the hydraulic system being slower to react, the electronics will also detect this with input and output speed differences not meeting the algorithm and likely ramp up the engagement oil supply to the oncoming clutch to engage quicker and firmer to reduce slip. As you come to a stop, assuming a rolling stop, it's more so the lockup disengaging, this is also assuming the Grenadier TCM is programmed more towards a commercial vehicle then a passenger car which would drop or slip the lock up earlier for comfort. TC lock up can be controlled in any forward gear and has three states, engaged, disengaged and controlled slip. First gear only releases when stopped in gear foot on brake by keeping one clutch engaged, releasing one clutch and control slipping the third clutch required to deliver drive, this is to reduce fuel use, NIC neutral idle control.
It will be interesting to see if some of the new Cummins 6.7 gas engine and ZF Powerline 8 speed (big version of the Grenadier 8HP) in the new RAM trucks will share similar shift quality issues.
Images of ZF 8HP 45 for reference. The basic construction and operation remain the same over the models and generations with changes in ratios and component sizes.
View attachment 7899585View attachment 7899594
If someone can't follow this, here's a good general overview. It's German, use the translation if necessary.
View: https://www.youtube.com/watch?v=6wpzrbl7C5M
So the ZF units run four planetary gear sets to get 8 forward gears vs the 3 for 6 shown in the video @AWo posted. Pretty clever really.
They really didn’t test this truck out much to see if all their ideas were practical in application. If my truck is facing down hill when I start it and pull out, it won’t upshift. Drifting up to the 20mph speed limit has the engine howling. I have to step on the gas pointing down a steep Pittsburgh street, and then jump on the brake. Stooopid. I can push a button on my diesel f350 and have it act similar, but it’s driver activated for the situation. Wtf good does that do me in the Ineos?
Being accustomed to manual transmissions I actually like this feature. Yes, there is a manual mode for the transmission but why bother for daily driving? Yes, I live on a hill.
There are shops that reprogram the shifting in bmw’s for the “sporty” type owners. I wonder if they can make this act more like a car, or if a TCU or whatever controls this tranny, and be swapped in from a regular old x5. I drive in traffic jams every day, and shifting to N all the time is a bigger pain than my h55f.
I've been wondering for a while whether the mechatronic unit that controls these transmissions could be swapped from one trans to another - like from an 8HP51 into an 8HP76.
The new 8 to 10 speeds are now using 3 clutches for the gears plus a torque converter lock up, more complex gear set combinations and concentric drive drums, a big change from what we were taught back in the day when a six-speed using basic on/off solenoids mixed with old style hydraulics was the newest design.
Reactions: AWo
There has been some mention of interchangeability and people are trying it. The information has come from people tuning and doing conversions with older 8HP70 and 8HP45, some builders saying the valving is slightly different and can work, the TCUs are mentioned to be the same, but OEM software may be an issue, also part numbers for the unit can change within the same series of transmissions. People are also using stand-alone controllers with less sophisticated software then ZFs software for their conversions. There is still a lot of trial and error and testing happening with non-OEM changes to the transmission.
I get the same thing under braking from time to time. I’ve tried to intentionally recreate it but I can’t. It sounds/feels like I’ve run over something or there is something moving around underneath the vehicle. I can’t for the life of me figure it out.
Did you ever figure out your noise? I occasionally hear the same thing. Sounds like I have driven over something and kicked it up into the undercarriage. It’s a loud thud. I cannot replicate it consistently - just randomly happens. Doesn’t feel like a transmission downshift.
How do you shift to N while driving? I am always afraid of the pushing it beyond N into R..
I know it’s all software controlled so it shouldn’t do that, but it’s hard to overcome that fear
Why would you shift to Neutral while driving? Serious question: shifting to Neutral and cruising in "Angel gear" may cause unintended consequences re. reduced oil pump pressure in the ZF transmission leading to lubrication loss and ultimately bearing failure...
perhaps someone with more understanding can either tell me I'm "dreamin!" or expand on this... .🤔
It may be a random solenoid actuation with more force than normal. I've experienced this with older auto transmissions when the pressure line adjustments had strayed beyond their limits. Especially noticeable when gently slowing down (usually below 20mph/30kmh) and the auto was supposed to slip into second or even first gear... it would "thud" into lower gear...
Sounds like a mechatronic issue...perhaps a sticking valve or dodgy connector🤔
They call it normal.
Its from 10-0 mph if you do it. which takes a second. youre dreaming. Youre talking about people that thought a long downhill in neutral would lower RPM and save fuel. I dont think anyone buys an ineos to save the planet.
I occasionally get a clunk if breaking hard and turning hard right. Only doing around 20 mph when I have experienced this noise.
l have a 2022 Defender with the ZF 8 speed transmission. l believe the same as fitted to the Grenadier.
l had similar, an occasional "thud" when slowing down at lower speeds. l put it down to the transmission.
Over time, the effect gradually went away and now at just over 20,000 miles it never happens.
To be clear, mine will clunk but not every time. I seems speed and deceleration, need to time it right with the downshift. Kinda like committing a crappy downshift in a manual.
I have the same issue and mine, it is at the dealer now. It did it 3 times on a test drive with the service writer and he acted like he could not hear it. They put me in a loaner and it drives perfect.
I picked my Grenadier up yesterday and noticing once in a while a little clunk I feel and hear. It seems to be coming from underneath by the pedals. Seems to be happening when slowing down for a light. I heard there was a steering recall where Non-locking nuts may have been mistakenly installed on the steering rod ball joint. They said this can cause a clunking but mine seems like not coming from steering. I would think my truck was checked for this at the dealership. Maybe a tranny down shift clunk idk. Anyone else experiencing this? I’ll keep you posted if I figure out more.
I too am experiencing a clunk while slowing down or slightly applying the brakes at speeds less than 40 miles an hour. I feel it under the pedals and I have an appointment with the service department on December 17 to investigate. It is fairly easy to replicate by accelerating or driving at normal street speeds and then lightly applying, feathering the brakes.
