Brake fluid flush
Gxgn
6:29 PM
Iowa, USA
Hello, has anyone done a brake fluid flush himself, not at the dealer? Do you know if there is a system reset procedure if you tackle this project to avoid a long drive to the dealer? My brake pedal holds too close too the floor for my liking and I think a brake flush would help.
Thanks
Thanks
Currently no way to do a reset without dealer doing it for you. However the braking system is typical except has a manual rear break aka the brake lever, so no need to home the rear brake if you are doing a pad swap your self. Anyway yes you can bleed or vacuum bleed like normal. Mine is actually really hard or I would be doing what you are asking, bc I hate sloppy brake paddles.
