BMW recall to impact Grenadiers and Quartermasters?
LeeroyJ
2:09 PM
Arizona, USA
This Article "BMW to recall over 196,000 U.S. vehicles due to engine starter defect" indicates that the Toyota Supra is involved in the recall. The Supra uses the same engine as the Petrol Grenadier/Quartermaster (the B58), so I wonder if this issue impacts our vehicles?
BMW is recalling over 196,000 vehicles in the U.S. as the engine starter relay may corrode, leading to overheating and short circuit, increasing the risk of a fire, the National Highway Traffic Safety Administration said.
The issue affects multiple models including the Toyota Supra and 2022 BMW 230i vehicles, the U.S. auto safety regulator said on Sept. 26. The Supra has been built by Toyota in a collaboration with BMW, which includes a shared platform.
BMW dealers will replace the engine starter, free of charge, NHTSA said in the notice.
It was not immediately clear how the Supra recall would be handled.
Looking at the Consumer Alert posted on the NHTSA site (pasted below) it would appear these engines pre-date the Grenadiers in the US.
September 26, 2025 | Washington, DC
BMW of North America has issued a new park outside recall for nearly 200,000 model year 2019-2022 BMW vehicles due to a risk of fire while parked or being driven. Owners should park outside and away from buildings and other vehicles until they either confirm their vehicle is not subject to the recall or have their vehicle remedied.
The recalled BMW models are:
  • 2019-2022 Z4
  • 2019-2021 330I
  • 2020-2022 X3
  • 2020-2022 X4
  • 2020-2022 530I
  • 2021-2022 430I standard and convertible
  • 2022 230I
The recall also affects 1,469 2020-2022Toyota Supra vehicles manufactured by BMW.
The engine starter relay in the recalled vehicles may corrode, causing the relay to overheat and short circuit, which may cause a fire.
Due to parts availability, BMW will be conducting a phased recall. Interim notification letters to owners are scheduled to be mailed on Nov. 14, with a second notice being sent as remedy parts are available. Owners can call BMW customer service at 800-525-7417 with questions.
The vehicle identification numbers for affected vehicles will be searchable on NHTSA.gov starting Nov. 14. Starting on that date, owners can visit NHTSA.gov/recalls and enter their license plate number or 17-digit VIN to see if their vehicle is under recall, or or call NHTSA’s Vehicle Safety Hotline at 888-327-4236. NHTSA also encourages everyone to download its SaferCar app to stay informed on current recalls.
The IG uses the XIX1287 Starter Motor. That is shared by many more vehicles than the recall:
Whereas the Z4 and Supra uses XIX1435 Starter motor
Mine is in for a service and several campaign fixes today. One of the campaigns listed was an inspection of the starter motor wiring. I don't know if its linked to this or something different.
You’re seeing the result of a "size vs. power" paradox in modern engineering. While it looks puny compared to the massive "iron lung" starters in an old Land Rover Discovery (like the 300Tdi or the V8), the modern unit in the Grenadier’s B58 engine is actually more capable.
Here is why that modern starter is smaller but technically "beefier" in terms of performance:
1. Permanent Magnets vs. Copper Windings​
Old Discovery starters used field coils (large loops of copper wire) to create a magnetic field. These were heavy, bulky, and generated a lot of heat.
Modern starters, like the one on the Grenadier, use Permanent Magnets. These allow the motor to be significantly smaller and lighter while producing the same—or more—torque.
2. Gear Reduction (The Secret Sauce)​
Older Land Rover starters were often "direct drive," meaning the motor spun at the same speed as the gear turning the engine.
Modern units are Planetary Gear Reduction Starters.
  • Inside that small housing is a tiny gearbox.
  • The electric motor spins at very high RPMs with low torque.
  • The internal gears "trade" that speed for massive mechanical leverage (torque).
  • This allows a motor the size of a soda can to crank a 3.0L engine faster than the old "giant" motors ever could.
3.​
