BFG K02 Tires Pressures Normal and Aired Down
ShootingCar
5:18 PM
Cottonwood, AZ, USA
Hi everyone.
I have the standard BFG K02’s that come with the Trialmaster.
What do you all typically run your tires pressure for on the road and aired down for Offroad?
Thanks
Jeff
38 road -> 2,6 bar
25 offroad -> 1,7 bar
18 or less (down to 10 in real need) on the beach depending on conditions -> 1,2 / 0,7 bar
25 psi/1,7 bar sounds a little high for offroad unless this means easy tracks, dirt roads or similar.
18 psi / 1,2 bar is my typical offroad pressure
Mine were overinflated by the dealer on delivery. It looks like they were inflated for heavy loads and were going to 42PSI on longer runs, and the car would start to feel unstable on the road (needing constant corrections). I dropped them to 36PSI cold as per the recommendation for normal load and they have been fine since. Thats on the 18 inch.
Meaning after driving a long distance?
Tyre pressures rise when the tyre warms but this is normal. It should not be deflated because of this. Measurement always at ambient temperature.
Correct, they rise when the tyre warms but if they are already high when cold, they will be even higher when warm. Hence why you set your PSI when they are cold. Not after you have driven 100 miles on them and they are warm.
Can confirm Just got my new Grenadier home. It did seem to ride a bit rough. Checked the pressures the dealer had them set at 46psi all around!
Just dropped them all to 38 hoping the ride improves.
46psi... so probably 50psi once warmed - far too high for comfort and will likely cause some uneven wear long term. 36-38psi all around for highway and will sit circa 40psi when warmed - this feels best in my experience.
