Build Thread Bed Board Build
Max
9:23 PM
I designed and had a "Bed Board" made to fit on the double seat side of the Gren.
It is made from Falcuta Light Weight Plywood which is used in caravans and camper trailers ect. It's 1900mm X 800mm X 15mm and complete with piano hinges it weighs only 11.6kgs. The side profile on my plan shows the hinge setup with the dots. I used the radius to acheive maximun width and softer corners than just right angle cutouts.
I wanted it hinged, it could be one piece or two. It is so versatile hinged and as the U shaped pic shows with the verniers, right angle latches across the corners and horizontals across the middle could make it a workable table or just leave it as a flat shelf. The front behind the passengers seat is supported by the rear seat and a small spacer on the centre console lid. The back half is resting on my old but faithful crates that just so happened to be perfect size. It could easly be the lid of installed boxes or drawers.
The hinges are in place to fold up neatly and to work against folding while you lie on it. It is designed to sleep with your head at the back door so your torso is over the main support plus being able to open or close the door. Then your feet are at the end with the least amount of support which works ok. If you wish my plans are yours. (y)
Attachments​
Attachments​
Looks great and very compact when stored
I carpeted mine but you have to sleep diagonally as it is only 1500mm straight. 59"
It works out to just over 2 metres diagonally 78.7"
Attachments​
Attachments​
Looks good . I have been thinking of a simple , removable option like this . Could you share your plans with me please.👍
Hi Dave the BED Plan is one of the pictures attached...very simple...each panel is 800mmX475...Two panels with the radius of 150mm on corners and Three piano hinges 770mm. The BED Hinge pic has the top of the bed facing toward us in the pic so you can understand how it folds and placement of hinges. The back half towards the back door has to be fully supported and that is for your torso so your head is at the back doors...hope it all helps but please don't worry about questions cheers (y)
Ok thanks , I’ll give it a go
Reactions: Max
