Battery drained - Now error messages!
10:05 PM
Got a flat battery, jump started it and got the following errors in the below photos. Also getting Airbag Error, ABS and ESC off messages.
The front and rear diff switches are also flashing orange.
Anyone have a remedy for this? Can it still be driven to speed up the charging process?
Where are you? I'd charge it externally to at least 50% and then use an OBD tool to clear what codes you can.
Airbag error will have to be fixed by a dealer.
Mine did same over Christmas camping. I drove no worries.
Did have to go to dealer to clear air bag. The rest cleared up with charge and restarting.
The cause was opening and closings doors all day. I now just leave adjar while camping. Seems to be working fine now with Engle draw fridge in back.
If your battery dies, all idiot lights can be cleared except for the airbag?…add that to Lynne’s List.
I don’t kill my battery often enough to notice but I don’t recall this ever being a problem on other vehicles i’ve had. Am I missing something?
Does this same thing apply if I disconnect the cables/power to do electrical work on the truck? Same difference, right?
I would disconnect a battery terminal and charge the battery. When you have a reasonable charge in the battery, reconnect and the lights will have gone with the likely exception of the airbag.
For newbies to this occurrence , Íf it goes completely flat, let the jump start battery feed some electrons in over 5-10 minutes at least before trying to start.
Maybe Rok Dr would know if there's an issue with my plan. I'm thinking of putting a secondary contractor between the batteries, where I can activate the coil with an unused overhead switch or a dash button, so I can manually connect the batteries for instant jump and winching. Any reason the "system" would see this and loose its frigging mind?
Same thing happens on the new defender opening and closing doors too often. Computer booting up draws a decent amount of power. Stupid system. I wonder if leaving the small boot door ajar is enough?
Thanks for the responses.
The IG software is has a mind of its own. I have seen the battery SOC drop from 90% to 0% momentarily then back up on previous occasions, so I don't think it was actually at zero. Took the car for a spin and got the battery back to 74%. Diff switch lights stopped flashing and their warning lights went away as I started driving. When it got over 60% battery warning lights went away, and at over 70% so did the orange check engine light. The only warning still remaining was the Airbag light. Hopefully the system has self booted now that the car has sat overnight but sounds like it's something for the dealer by your accounts.
I have the auxiliary battery in mine and the main battery has dropped to 0% many times with my fridge, phones and dash cam left on with PWR switch on.
Usually takes a couple or 3 days of no use.
Always starts, but flashes battery low in red, then amber until over 50% charged.
What we need is an OBD reader that can check the airbag sensors and so on, letting us know if there is an actual fault (most people who want to stay alive would want that information) - or not. The latter situation being clearable.
I’ve run into this before — when your battery goes completely flat and you jump start it, a bunch of error messages like ABS, ESC, and airbag can pop up because the systems didn’t get stable voltage during boot-up. Sometimes they clear out after a proper full charge or short drive, but if the battery is weak or not holding charge, the errors can keep coming back.
You can usually drive it to help recharge the battery, but only if the car is running smoothly and brakes/steering feel normal. If the diff lights are flashing orange, I’d be cautious — might be better to get it properly checked.
I’m based in Dubai and use Battstorm for these kinds of issues. They offer mobile battery testing and replacement — super useful when the car’s acting up right after a jump start.
Might save you a lot of hassle if the battery needs replacing anyway.
Had a dead battery as well. The only warning messages I can not get rid off are the airbag and ecell since then. As the car is in for its 2nd inspections now anyway they will clear them.
But for the future I would want to have a method to do it myself because I defiantly want to avoid driving 50 min to the dealer and have them doing it for me...
Did anybody figured out a way to clear these error massages by himself?
THX in advance and greetings from Germany!
I believe the answer will be ''no''.
Still catching up on posts here, hence the delayed reply.
My understanding is if you have the smartpass battery option fitted then your idea would only duplicate what the smartpass already does electronically. If you don’t then it certainly could work. In this case you would just have to ensure that it could charge the second battery.
Happy to be proven wrong
Cheers
Steve
Cheers
Steve
The ctek has a 120a limit. I'm talking about letting the ctek do its thing in most situation, but when winching, closing a 500a contactor combining both batteries.
Gotcha. Having a dig into the specs it probably wouldn’t be necessary:
  • The winch is protected by a 150amp fuse under the bonnet so it can’t draw any more than that.
  • The alternator has a max 250amp output, so theoretically it should be able to keep up with the Winch draw.
  • The alternator charges the starter battery and the only way to charge the aux battery of through the smartpass.
Cheers
Steve
Cheers
Steve
I'm planning for a twin motor gigglepin. The manual override is also the setup in my existing rig, for an 8274, and the motor speed difference indicates less voltage drop and I'm using 2/0 dlo, so I've just assumed internal battery C limit resistance. 2 300a contractors with a dash switch feeding a 500a e-stop. It looks like I can have the estop poking out low under the rear seats. out of the way but an easy hit for me. Either that or a simple combiner 'off, a, b, a+b' combiner switch there. But, I've put off dumping a ton of money into the rig until all the warranty issues get sorted, but being on week 6 of not having a truck, my optimism on making this investment work is waning.
