Alucab Grenadier Specific Loadbar Feet
cdsvt
3:32 PM
Vermont, USA
I installed the Alucab specific load bar feet last night. Installing the loadbar feet was straightforward and only takes one tool - a t30 socket.
Adding the Alucab loadbar was a bit of a hassle getting some of the washers/nuts on. Each foot has two nuts/bolt/lockwashers holding the bar to the foot. The inboard washer/nut was easy, the outboard washer/nut was a massive hassle. It might be easier with tiny hands. This step took the longest by far.
If I did it over, I'd try installing all of the 13mm head bolts in the feet before installing the feet on the vehicle. Just getting the locknuts on a few threads, not tight. Then after installing the feet, slide the crossbar in, get the spacing right, and then tighten them down. This would easily have saved me 30 minutes.
I already owned the load bars (and the tent that goes on them), so this was a quick and easy way to add a low profile load bar system (and allow me to use my RTT).
Oh, and the instructions are silent on which positions to install the feet in, so I installed the feet in the forward two bolts on the front and rearmost two bolts on the rear.
Hi - interested to know how the load bars have functioned with off reading and corrugations. And can you tell me the weight of your RTT?
I have a 75kg RTT mounted by the load bar feet but im worried that the 6mm bolts are big enough to hold the weight when off reading.
Love to hear how you have found them.
Thanks
I have the Alucab 3.0 and it is 76kg. I've had it offroad on all kinds of trails from mild to serious (navigation error on my part). It is held on by 4 bolts total. It has been solid and hasn't moved at all.
