Alarm
Leonidas
7:56 AM
If you sleep in your Granny and set the alarm,will the alarm be triggered if you move ?
If yes ,is there a simple solution to stop that happening?
Try it. Stay inside the vehicle, lock it with the key fob, wait 10 minutes for the electrics to go to sleep. ( you'll hear the relays de-energiseing. ) Then move about and see what happens.
Then repeat, but using the internal door locks instead of the key fob.
So you intentionally set the alarm?
But you only want the alarm to trigger for certain contrived situations?
I would like to alarm the car before sleeping so that it is triggered if someone tries to open the door
And also the possibility to activate the alarm with the kefob if I see/hear something suspicious
Not sure the alarm would be activated if the doors had been manually locked
I often sleep in the rooftop tent with the vehicle locked. Moving while in the tent has not yet ever set the alarm. So I assume you would be ok. (BTW: Grenny, not Granny :))
Slip of the finger, not the tongue thank you for correcting
Well, yesterday my "Front Runner Extended Hi-Lift Jack Adaptor 250mm" arrived that I bought for my Hi-Lift, because I have the Buzz-Overland rock sliders and they have a hole for this. I tested it today (forgot to take pictures).
https://4x4deals.be/collections/jac...ont-runner-adaptateur-pour-cric-hi-lift-250mm
So, I begun to lift my car, in fact tilting it, and my alarm went off!
Why? Because my car was locked!
Good to know that the alarm works.
Probably only because of the tilting.
Exactly as a did with mine to test the jack on my side steps. The alarm went off because the vehicle was locked. 👌🏼 Hope fully sleeping in or on top of the vehicle will not rock the vehicle enough to set the alarm off.
