Agile Offroad Sliders
Mister_BevilAcqua
6:37 PM
HTX
For those of you with the Agile Offroad sliders, do you find them too high to use as a step for entry, especially for those of you with a lift and larger tires?
I love how they tuck up close to the bottom of the door, providing more clearance and the best aesthetics, and unlike any of the other offerings on the market, but I worry they might be too much of a reach and possibly an added obstacle for the misses and any other passenger shorter than average.
Lastly, did you choose aluminum or steel, and why? My alternate considerations are Dissent (if they bring them back), Metal Cloak, and Dirtbox Overland (insanely pricey).
Thanks for asking this question @Mister_BevilAcqua as I have the same questions....
Over the weekend I put on some used, really good condition, Owl Slider/Steps. They look nice, but it appears the passenger side sits tighter to the side rocker than the driver side. ....:cry: O/A, they are only 1 inch higher than the OEM side steps that came with the IG (14" from 13" for my IG). So, after install still had me thinking Agile Offroad Sliders might be the way to go even with the need to drill into the IG (doesn't just use factory bolt locations).
I hear aluminium is grabby and steel will allow more sliding over obstacles (but you take the weight hit. obviously). When I inquired with Agile awhile back they recommended aluminium, but that just made me think they are selling more steel and have too many aluminium sliders in stock 🤣.
Dirtbox Overlan says this:
"Built with the strongest materials available, they are designed to absorb impacts and prevent damage". I'm sure they are not made of Graphene, Carbon Nanotubes, or Lonsdaleite (but priced like it)...Steel?
Also don't like this with Dirtbox Overland sliders;
I also like those ones. Check out Goliath off road as well. They appear similar. Someone in the sliders thread recently mounted them and loves them. They appear to be what you’d like. I’m not sure I want the stainless tops, so I may ask them if they can sell without. My questions are the same as yours, and I’m slow to pull the trigger.
I didn't realize you have to drill into the body with the sliders from Agile, not a fan of that. I called Dissent earlier, and they have no plans to make the sliders in the future, so those are officially off the table. If Dissent is a no-go and those from Agile require drilling the body, then my decision might be made for me with those from Metal Cloak.
I am vertically challenged so most true sliders were out for me and as a guy of a certain age with rods in my back I need a bit of a step. While I love most things Owl, for me their steps are a bit too busy with the mesh down the length and they are a bit wider than I wanted hanging off the side of my Trialmaster.
I opted for Buzz Overland steps, they are stainless and bolt up in minutes with no alterations.
@INEOS OG who made your passenger and driver side A-pill grab handles? I have Agile Offroad on mine, but yours look shinier.
I really like the BuzzOverland stuff, Ryan knows what he is doing. I have some bumper lights and the spare tire storage mod from Buzz.
You have to drill, but the holes are where you've removed the stock plastic trim. If you ever decide to remove the Agile sliders, you'll reinstall the plastic trim and it will cover the holes up.
The bigger question is whether you want sliders that attach to the body versus ones that attach to the frame (or the body mount perches, which themselves are attached to the frame).
I've always favored a true rock slider that attaches to the frame, especially on a heavier vehicle. Most of those that attach to the body (on other vehicles) attach at the pinch seam, which isn't favorable. The way that Agile has gone about it is slightly better, but it's still not a true frame-mounted slider.
We love ours. My wife is 5ft 3 and never said a bad word about them. They work great as an additional step to get in. The kids love them too for the back. They can get a little slippy when wet and muddy though. The main advantage is the increased clearance. We have aluminium and they do the job for us, we haven’t fully tested them. We tested the one from the factory that took a big hit when we slid of a rock in Pakistan. They rusted after that but they did do the job of protecting the body. If you’re going to do serious rock crawling type stuff, get steel, if not aluminium should do the job. 👍
Those are from Racefoxx in Germany. Initially, I went with the OEM Ineos left side handle parts (handle, A-pillar trim, mounting hardware, and hardware cover) for a year and it never fit right. Most recently the A pillar foam around the grab handle started to yellow and looked shabby so I started looking for aftermarket solutions.
The usual places make a nice product but were less finished than I wanted then I found these. They were not cheap but they are substantial. They come in this gray and black both were a bit shiny for my taste but are less shiny inside the vehicle. I paid less for the pair than I did for the initial OEM handle from the Ineos / Bentley store in North Carolina even with DHL $hipping.
The center console, switch hold downs, and transfer case selector is Grenadier USA, the utility belt is from Tiny Rig Co., the ZF shifter is from Toyota.
I loved the idea of them, I would never get Al over the steel. But, I decided that’s. Long wide flat section of metal the has no internal gusseting to prevent deformation, and it’s attached to the seams of the truck body, at point not intended to carry a load.
I had consider buying them and welding a 4” or wider strip of 1/4” along the bottom, to provide rigidity and resist deformation, but, metalcloak had a sale, makes something that will take a hit, and I can power coat for free, so…
