Accessories Mounted on Rear Ladder
Used 3 of the DVA Mechanics clamps to mount my 48-in. Hi-Lift to the rear ladder. I'll add the neoprene boot to the bottom and the handle isolator at the top (note, jack base removed - I keep it stored with the rest of the Hi-Lift kit inside the truck).
Sadly, as mentioned above, if you orient the clamps 180-degrees so that the entirety of the ladder rungs are free of obstruction, the Hi-Lift will bump into the tail light when the smaller door is fully opened. It's possible that the neoprene boot would prevent damage, but why take the chance?
It looks great -- we have a longer clamp (we haven't listed it for sale yet) that has an extra 1" of clearance away from the ladder. Would that help to clear your tail light? If so, I'll send you a set to swap them out. Can you send a side view picture?
Thanks - I think I’m good as-is since most of the ladder is still accessible.
It seems the ladder rungs protrude to different degrees since the bottom portion of the jack contacts the rung while the others don’t. A bit of rubber tape on the rung and that problem was solved.
I bought some longer M8 bolts to hang the jack on (the ones that come with the DVA clamps are too short for my use) and some 4-prong female m8 nuts in lieu of wing nuts (they’re kind of small at M8 size).
Calling this complete at this point. View attachment 7879458View attachment 7879459
That is a sharp set up.
I'm installing my ladder sometime soon (had dealer throw one in my trunk during sale), I'm hoping to add a chainsaw scabbard on the left side of the ladder. Anyone done this yet with a Mac's tie downs scabbard?
I (think) I would like to mount a small (one or two gallon) insulated water jug (with spigot) to the ladder. Any suggestions for mounting for these typically round containers?
I mounted GP Factor's Propane Tank mount to my ladder. Will post a longer write-up in my Build thread.
Thanks Nadir, perhaps clamps from DVA Mechanics could attach the ‘spine’ of the bracket to the outside surface of the rungs?
I might use 2 sets of the clamps - on opposite rails with an added flat bar connecting them, with the bracket mounted in the center. If the bracket is mounted to one side or the other the jug will likely hit the tail light or the spare tire. Some time with a tape measure will confirm.
Surprised to see so many people still schlepping around those bulky heavy Hi Lift jacks these days. With the availability of smaller and more effective axle jacks, you don't need the old school stuff any longer.
Recommendations?
But, - nothin says you are an avid off-roader like a powerful big, heavy duty farm jack!
There's more uses for a high-lift than just jacking up the truck. Even if I were to add one of the hydraulic jacks to my trucks, I'd still carry a high-lift.
