So I just came back from a big trip to Cape York.
The Grenadier performed great - although annoyances with AC/TPMS/Diff lock continued.
One interesting thing which happened was a stick getting flicked up behind a harness which connects to the rear diff lock and the rear left ABS sensor - breaking some wires and ripping some out of a connector. That resulted in the errors shown in the photos shown on the cluster and centre screen.
So there was an ABS fault - then a whole bunch or other errors. My understanding is that there is the ABS error (which is understandable given one wheel speed sensor is no longer connected) - then all the other errors are secondary due to the other modules no longer receiving an accurate vehicle speed signal from the ABS module (so the Trailer stability / downhill assist / uphill assist / power steering / engine and transmission faults). As an ex powertrain diagnostics engineer I was pretty disappointed to NOT see a message just saying something like "rear left wheel speed sensor open circuit". So no message which actually indicated the root cause of the problem. Apparently there was a code saying that on the ABS module but it does not get shown on the centre screen.
On calling Ineos support (and being 1000km from the nearest dealer) they said "are there any warning in RED? no? then keep driving!". Faced with a big wait for a tray truck or a long drive with no ABS I chose to drive. It was interesting to note that if you then locked up the brakes (was driving on lots of poor dirt roads) then the transmission module would flag a red error and go into limp home (seemed to be stuck in 3rd gear). That reset itself if you stopped the car and waited 20 minutes.
The issue was solved for me by driving a few days with no ABS to Wesco Ineos Cairns - who quickly diagnosed and repaired the harness.
When you are sitting in your Grenadier in 1000km from anywhere with the transmission stuck in 3rd gear and waiting 10mins with the key off for the error to clear - it really make to realise it would be good to have an OBD tool for this vehilce! As I understand it the ABS module is hidden behing the gateway module and so only Ineos tools can see diagnostic codes / DTCs on the module.
Come on Ineos - repair manual and OBD tool - get on with it - the owners need them!
