2023 differences to 2025
Forbsey
9:15 PM
Wimborne UK
I am about to buy a late 2023 station wagon with some really nice extras. I was wondering what are the real differences between a 2023 and 2025 model. I was told the reversing camera display is a little smaller on the 2023 version but what about more important differences????
My understanding is that 2023 cannot be software updated to newest version.
This was what a dealer told me when I asked about adding trailer controller.
There is a change with the display unit and processor that makes not all updates retrospective - look for a 2024 or later. (Mine's a 2023).
(From the manual and parts list, there is an upgrade path, replace bits for the more recent, but it is unproven and likely to be very costly. Something to dream of in 10+ years time and I can find an abandoned/wrecked Gren to part out).
I have an MY23. Have driven the MY24 and 25 as loaner vehicles during service works and tbh other than minor cosmetic differences like the rear camera size and the menu position when apple CarPlay is active there was nothing obvious. I have a fully loaded MY23 diesel trialmaster with dual batteries, dual lockers, safari windows and almost all options except the winch. Love it. Wouldn’t change it for a new one.
Folks who have the 23 don't realise the challenges of a 24+ with the ADAS and the safety systems.
I would say if you can get the entire work history of the 23, and get the Ineos dealer to sign off on all recalls, then get a good check at the axels to make sure there is no past or present leaks / signs of leaks, check the drive shafts, boots for them. If all this looks good, check of signs of water ingress inside the cabin, make sure the HVAC works to heat and cool, and then finally see what you make of the power steering pump noise.
If all that is positive, good clean car, get the 23 over the 24/25 model. And don't be afraid of work done, work done is a good positive thing. And just an emotional thing for me is to never buy a car that's been sat around for periods of time. A Grenadier used, maintained and looked after is likely a better than option than one sat at a lot or in a garage for months on end.
Just a side note - depending on where you are in the country, someone on the forum maybe willing to come look at the car with you once. Generally a motivated bunch on here.
All the best!
Thanks for all the good advice. The 23 model i am looking to buy is from The Grange up in Edinburgh. Ex Ineos car with only 4k on the clock. Looks clean but will check for all the leaks from the Safari roof.
Didn't they forego the dual battery system in 2025 or is that just rumor?
During 2025, they did that.
I believe added the hitch as standard too.
Still a cost option:
Overall, the MY differences are mainly service bulletin issues being fixed on the factory line. The only visual differences are the head unit (the rear reversing camera in particular), ADAS, and the steering wheel offset that was common on MY23. The windscreen upper trim is missing on the latest models (possible cost-saving measure - possible fix to something). There is also more sound insulation than the MY23.
Getting the factory fit tow ball and electrics is a no-brainer. Considerably more expensive retro fit and a factory fitted will be a money +ve advantage at resale/trade-in
I have had extended periods in both and agree there is outwardly little difference other than those already outlined. I see you are in the UK so be aware that there are quite a few ex Ineos vehicles floating about which may be ex demo or display vehicles that have come from dealerships that have subsequently shut due, I believe to changes in IA policies. Don’t go by the year letter on the numberplate but rather check the paperwork for actual manufacture date. 24 onwards have the ADAS gubbins that come with the associated bings and bong chimes and extra warning lights if the camera can’t see what it believes it needs to see to remain happy.
I should have qualified *NAS spec. The OP appears to be Stateside so I didn’t think to specify.
