yet another issue now (AC problems)
Leonidas
11:05 PM
yesterday 27 Celsius 2 hours stuck in traffic and...NO A/C
I tried playing with the knobs ,as it had worked before when heating is temperamental, but nothing worked
i searched the forum ,read an article suggesting not using auto ,fan on 1 ,temp at 21... did not work
stopped engine restarted several times (after waiting at least 10 seconds after the warning lights come off) nothing but warm air blown
checked the engine bay 3 pipes come out of the aluminium block : the left and center ones were "room temperature",the one on the right was hot
I am due to make a trip to France on 2 weeks time .What would you suggest I do ?
Get in to the dealer and get the system checked..
Was it running and became warm or hasn't it run at all and didn't start?
That a pipe is hot is normal. The compressor sucks in the coolant from the evaporater in the inside of the cabin. The colant is gaseous now and carries the temperature (energy) from the cabin. The hot pipe is the exit from the compressor going to the condenser (hopefully, otherwise something is wrong. Check it). Because it compresses the gas it becomes hot (it needs to be hot to have a much higher energy level that the environment). Then it passes the condenser in front of your engine. There it transfers the heat (energy) to the environment and condensates back to a liquid, but still under high pressure. It runs through a filter and a water separator and then it enters the expansion valve which is next to the evaporator (the pipes into the evaporator and out are running through the valve as this regulates the amount of liquid which is allowed to enter the evaporator. It is not allowed that too much liquid enters the evaporator because of the chance that some liquid maybe not evaporate. If that remaining liquid enters the compressor it will damage it). By expanding the liquid in the valve and releasing the pressure it becomes very cool before it enters the evaporator and all starts again.
AWo
Some owners have had leaking joints or abraded/leaking pipes.
Dealer to check.
Reasons could be too less coolant or an iced A/C. The latter happens at high temperatures and humidity. Switching off the A/C and let the ice melt helps.
AWo
AWo
I tried again this morning,unlikely it would be ice
To be noted : putting temp on maximum cold or heat did not make any difference in the temperature of the air blown into the cabin
That a pipe is hot is normal. The compressor sucks in the coolant from the evaporater in the inside of the cabin. The colant is gaseous now and carries the temperature (energy) from the cabin. The hot pipe is the exit from the compressor going to the condenser (hopefully, otherwise something is wrong. Check it). Because it compresses the gas it becomes hot (it needs to be hot to have a much higher energy level that the environment). Then it passes the condenser in front of your engine. There it transfers the heat (energy) to the environment and condensates back to a liquid, but still under high pressure. It runs through a filter and a water separator and then it enters the expansion valve which is next to the evaporator (the pipe into the evaporator and out are running through the valve as this regulates the amount of liquid which is allowed to enter the evaporator. It is not allowed that too much liquid enters the evaporator because of the chance that some liqud maybe not evaporate. If that remaining liquid enters the compressor it will damage it). By expanding the liquid in the valve and releasing the pressure it becomes very cool before it enters the evaporator and all starts again.
AWo
AWo
Thank you for the detailed description of how the system works.would there be any lessons to be learnt from the temperatures of these pipes, like compressor not working,loss of gas...?
When it didn't work right from the start it is not icing. Icing develops over time.
Less gas, less compression, less heat of the pipe....but you need references to come to a conclusion.
Like the other ones suggested, you can't do anything on your own. You need the rights machinery, material and knowledge for that. So get the car to a workshop which can handle A/C's.
AWo
Another bad news: second dealer around London now permanently closed
Any idea where I could have service and warranty work
If the pipes are getting hot and the heater doesn't work either it's likely a software bug. I have had similar with the heater, -won't blow hot-.
after a re-start it just works again. It could be that the unit needs to re-boot. But then if it's the same the next day.... maybe not..
Today , it does blow hot air but still nothing from A/C
I am quite worried with all these UK dealers disappearing
Where we you go for warranty and service now?
Your question: did not work at all from start
Did you check the fluids for the airco. They are mostly to low. There is a procedure explaining how to get air out of the cooling system. After that you refill the reservoir. You may do it a few times before it’s ok. Should have been done in the factory or your dealer, but mostly they have no clue. You can find this in Dr rock his manual
Has the A/C ever worked? When was the last time it worked?
Any good aircon technician could test whether the system has lost gas ( assuming aircon ever worked well, as it does for most people).
You might be able to get a warranty claim by contacting Ineos if documentation from a reputable tech found a fault.
Could be worth a shot if otherwise you have to take days off work/lost income to get to the nearest dealer.
Also worth doing as the dealers are booked up, and I'm guessing it would be preferable to have it working for a holiday to France for a small cost. It would be annoying to pay bit fingers crossed you can make a claim
Might be worth having a word with the dealer first. It is possible that the dealer doesn't have the air-conditioning regas equipment themselves anyway ( especially if it is a new setup dealer) and like a lot of things they outsource the operation to a local source, vis, new tyres, windscreen fitting and air-conditioning. By keeping the dealer in the loop it will help with any warranty work, as in effect if the local source has been approved by the dealer, you are going through the dealer and all costs may be borne by them as warranty.
Yes, I should have included that too, I was just assuming they were too busy. Holiday was stated as 2wks of and I know my dealers lead times are far longer.
