Wolfbox piggyback fusebox
chrsbe
2:47 AM
Sternwartestraße, Wien, Österreich
I am using the fuse tap to power my Wolfbox digital rear mirror. Currently it piggybacks on the FC21 "12v outlet" fuse in the fuse box close to the steering wheel. A common installation I guess.
I'd like to change that and need your help with it.
What I don't like is that the mirror powers on when the overhead power switch is turned on and the car is off.
I want the wolfbox just to start when ignition is on. No matter about the pwr switch.
Which spot in the fusebox should i use instead? What would you recommend?
I don't have the answer.. yet. But I have the same issue / concern. In an hour or two I'm going out with a meter to look for a different switched power source that doesn't energize with the overhead switch.
I use the obd 2 port adapter and it seems to operate that way.
Testing out my solar panel and fridge I noticed the mirror is also powered by the overhead power switch. So I am considering the same powering change for the Wolfbox.
My temporary solution: power-down the Wolfbox with a long press of the power button (a short-press only turns the screen off). I believe this is the same as unplugging the mirror, but I have not measured power consumption.
I used the 12volt power supply running to the cigarette lighter type socket in the center console as my live. That line switches off with the ignition.
If I want to leave the camera switched on in a car park I can flick one of the overhead panel switches.
I showed how I managed it elsewhere in this forum. Been working well for the past 18 months or so.
Being able to leave the camera on in front of the supermarket is a positive aspect of my configuration. Draining the battery while camping is the negative side. I prefer camping.
That’s why I wired mine to have the option.
