WOLFBOX 900 pro install issue
Chrisinboston
8:57 AM
Boston, MA, USA
I had my WOLFBOX pro professionally installed. Installer fabricated the plastic molding over back left tail light and put camera there. WOLFBOX technical told them to aim camera straight back.
I just spoke to WOLFBOX, there is no way to adjust back up lines horizontally so the camera is useless as it’s off by several feet. I am sure an older model allowed back up line adjustment.
Anyone else experience this.
Yeah, I think you need to be mostly centered. My camera has no adjustment left to right unless I mechanically angle it that way. I mounted mine inside the rear window just so I got it mostly centered longitudinally with the vehicle.
There are a few reviews out there that criticize the reverse lines and how they don’t line up even if they’re installed “correctly”, centered on the inside of the door.
The comparison was made using the infotainment camera. The. Wolfbox was definitely off regardless of the zoom adjustment.
The lateral alignment overlay is probably true, I just don't use the guide lines for lateral control, I use them mostly as a distance estimator. That is true for the cars built-in camera as well. I use wolfbox for far to medium distances and the built-in camera for very close distance to other objects.
Mine is installed in the 3/4 door near the vehicle longitudinal center axis but not perfectly in center. That gets the lateral lines close enough to center for very precise maneuvering.
Anyone know of a professional install place in the NYC area or Long Island/Westchester. Looking for a professional install with someone who has done it on the Grenadier so I am not the first. Thanks in advance.
I had Mark @Curry in Danbury install mine.
If you are willing to make the drive and spend a day in Albany, this place installed ours back in December '24 has now installed at least five of them...
Had the Wolfbox G900 Pro with 67 Designs mount professionally installed and thought others in the upstate NY/Albany area might benefit from our experience.
The work was done at Boomer McLoud on Central Ave in Albany which has been around for a long time. They got the learning curve of the install out of the way with us and we are very happy with the results.
We got the package that included the hardwire kit and polarizing lens attachment for the front camera. We also ordered the 33’ rear camera replacement cable. We had them hardwire it to an ignition tap in the fuse box by the steering wheel so it powers on/off with the key. With this it also powers up from the power button on the mirror without turning the key as long as the Grenadier is “awake.” The GPS puck is above the overhead panel and works perfectly there.
We mounted the camera in the same spot that’s been highlighted in a few of the installation videos, inside at the top of the large rear window as far to the left edge (when facing the closed door) as was possible. As has been noted, the sticky tape that comes with the Wolfbox to mount the rear camera is useless - we used a small screw to mount it.
If you reach out to Boomer McLoud, speak with Richard, the owner.
