Windscreen washer fluid reservoir removal???
Scotsitalian
3:33 PM
Aberdeenshire, Scotland, UK
Has anyone removed the front engine bay windscreen washer fluid reservoir from the front left hand inner wing area?
I believe my washer pump filter is blocked or clogged as the washer fluid pressure is pathetic and I’ve blown back the lines with compressed air with no improvement?
Just want to know how difficult it is to pull the filters out of the reservoir and clean the entire reservoir and filters out?
Before you do that. I would take the nozzles out and give them both a wiggle first and use tiny piece of black double sided tape to wedge it at an angle so it can spray to the centre. I did this last week and it did the trick for now.
Wing off job to remove it, However it looks like you could access the pump from behind the headlight.. They are fairly easy to remove...
Wing off job to remove it, However it looks like you could access the pump from behind the headlight.. They are fairly easy to remove...View attachment 7897990
Hi Tom,
Do you have the procedure for taking off the near side front wing to get access to the reservoir?
I see you have access to the workshop manuals, are you a service centre or dealer?
Latest posts
