Americas Why all the fuss about fuel economy?
Schneeman
8:28 AM
Washington, US
I bought my 2024 Fieldmaster Edition in March of this year. I had braced myself for poor fuel economy. I have had many 4x4 vehicles over the years so it comes with the territory. I'm currently used to it as I also have a 2017 F-250 Super Duty that gets around 11mpg. I don't drive much, so it's never really been a big deal. For example, my F-250 has around 46k miles on it and my 2016 Range Rover had about 40k on it when I got the Grenadier. That said, I find myself looking for excuses to drive it and have put a few more miles on it now than I would normally.
I'll get to the point. I work in IT services and I generally do not commute these days. I was forced to spend two weeks driving about 25 miles each way across Portland, Or. and out to Beaverton, Or. I braced myself for constant fuel ups and was pleasantly surprised that my nominal average was around 19mpg during this time. I'm including a photo from my personal best on a day when there was little traffic. In fact, since I have had it, my average mileage is somewhere in the mid-18mpg range.
The Grenadier gets better mileage than my Jeep Wrangler ever did (12-14mpg) and better than my LR3 or my LR4 (17mpg). The Range Rover did beat it out, but I expected that.
Vancouver, WA
2024 Fieldmaster, Inky Black
The mileage the computer calculates is roughly 1.5-3mpg higher than actual, just as a heads up
60 miles of mixed driving a day and the computer shows 19.7-20.3 mpg. Pump figures out to 18.5-19mpg. BTW … this is using ethanol free gas. The Grenadier absolutely loves the ethanol free stuff!!
It’s a range, not a mileage thing. Luckily, it is just barely enough for a round trip I do. But on a cross country, the issue is that my bladder and the gas tank have vastly different cycles..
@Schneeman petrol in e.g. USA is 1/2 price of the UK and 50% cheaper than Australia.
So any fuel economy questions are only relevant to one's country.
In Iran it's almost free I believe. Unlike speech.
Range is another issue.
Yeah the onboard computer is way optimistic. Mine showed an average of 18.5 my last fillup. (reset every time)
Ran the numbers manually (distance driven/ gallons of fuel) and am actually getting around 15.5
Also I dont trust the distance to empty calculation either. It will show >300 mile range for about 1/3 of the tank- then start dropping quick through the second third of the tank. Then it will hold steady at around 60 miles to empty before it starts running down fast to zero. Definitely not a linear progression.
I left my house the other day with a bit over 1/4 tank at 60 mile range- ran a couple errands drove no more than about 10-15 miles and the car started bonging aggressively on the way home telling me to fill up immediately and the range indicator dropped to 20. lol
C'mon Ineos! If its not going to be even close to remotely accurate then why have it. Just give me an old school analog fuel gauge- and do away with the obnoxious bonging. I've owned vehicles from the late 90's that had more accurate and much less finicky fuel gauge and range remaining calculation systems.
With as little distance traveled by the OP mileage would be irrelevant
For anyone who does remote touring especially when towing a van mileage is the be all and end all consideration
With a lot of trips I do it’s not uncommon to do 2000km in a week and have up to 1000 between fuel stops
I am planning a trip CSR that is 1800km between fuel stops so yes fuel economy is a very important consideration.
Even more so if running out can put you in a life and death situation in very remote locations
Vancouver, WA
On my first 18,241 miles I used 1,704.487 gallons of gas at a cost of $7,533.10, equating to an average of 10.70 MPG with an average price per gallon of $4.49. 36% of those miles were pulling a trailer. Anything that can improve that cost and add to range is a big deal to me.
Fuel efficiency is not an America problem. Even in South America the issue was closing time for the fuel stations. It would be neat to live somewhere remote enough that it was a serious issue and not just a matter of being dumb enough not to top off when you had the chance.
I let it run down because I was being obstinate, and I ended up putting in over 23 gallons… closer than I wanted. It’s a 24 gallon tank, right? And this was in a rural area, that was silly how close I cut it.
According to the computer, ha ha, I got 30.2 mpg (UK, so full size ones), over a 100 mile plus mainly motorway trip. Average speed according to computer was about 50mph. I did up to 70 on very short patch and other stop start but generally 60mph. From Chester to York (roughly). Lowest point approx sea level to 1221ft and then down again. I am a slow & careful driver.
I have done this trip both ways and got 32mpg but did have to try to achieve that.
The only way to accurately measure this is to fill up the tank, do your drive and track the miles driven, and then fill up the tank a second time. Divide the number miles you drove by the gallons you put in the tank (the second time). The more you do this the more accurate your records will be.
The computer is guessing based on fuel flow and speed. Its highly inaccurate.
This was something I often used to do years ago to check against the accuracy of the on board computer. I can't be bothered anymore.
I'm using diesel, surprise!!
Actually the vehicle knows almost exactly how much fuel has been used. Injectors are open for a very precisely measured period of time while pressure is recorded.
There are a number of other factors that will influence both methods of calculation, often small but they mount up...
Fuel temperature has a small effect on volume.
Odometers are affected by tyre size, even the difference between new and part worn.
Odometers are also affected by tyre pressures as the amount of flex changes.
Fuel station pumps are measured for accuracy in most countries, but there is a tolerance.
Diesel fuel in particular is more efficient at lower temperatures.
The only really accurate measurement is to run the vehicle over a very precisely measured distance.
Different pumps click off are more sensitive than others too.
I realised I was too young to be waisting my time doing economy runs especially as the fuel was free anyway. Problem is, I was just born tight fisted 🤣
I do exactly that, since the second tank ever to 34 thousand miles now.
Here's the graph up to 34+k:
The truck's dashboard MPG numbers are completely irrelevant, remaining range - outright misleading.
Overall gas mileage with factory tires - 13.91 mpg, since 33" tires were swapped in - 12.94 mpg. (edited after DiscountTire receipt was found).
33" tires will kill your gas mileage, even narrow ones.
