Which model Wolfbox do I need?
Mister_BevilAcqua
8:41 AM
HTX
Looking to use the Owl Wolfbox mount, but I am stumped on which model to purchase. It appears there are three: Dual Dash, Cabin, and Bumper. Any insight and/or pointers for install/setup would be greatly appreciated.
G900 Pro - if you only want forward and rear traffic cameras, i.e. a 2 channel dashcam. The forward camera is on the back of the screen. The rear camera is mounted at the rear of the vehicle. A popular option is to mount it inside the large rear door, high up and close to the vehicle centerline.
G900 Tripro - if you want a 3rd camera channel:
1. Bumper edition - external camera mounted wherever you like. Wolfbox suggests using it as a trail camera mounted on the front bumper and looking at the terrain in front of the vehicle. It shows what you're about to drive over.
2. Cabin edition - a.k.a. the Uber driver version. Inwards facing additional camera. Same benefits as a 3 channel dash cam. Watch/record yourself or your back seat passengers.
I had the G900. Recently I switched to the Tri Pro version with the additional bumper camera.
What I found:
+ The Tri Pro has a much better rear camera. Better in low light and the overall sharper image.
- The Tri Pro version's startup time is much too long. After a few seconds you get an animated Wolfbox startup sequence, and then when you're already out of the garage you see the rear camera activate. This is a major issue and the reason I can't recommend the Tri Pro version.
What I found:
If you update to the Tri Pro is the camera cord that runs to the rear stay in place and just swap out cameras?
