Where is this from?
Orcmurd
4:13 AM
over the bridge, on the left
Just found this lying in the boot, has Ineos logo so definitely off the wagon. Soft rubber suggesting some sort of door stop? Single hole in the middle, possibly a mounting hole?
That looks like a cable grommet.
They fit in a hole and allow a cable to be pushed through, sealing around the cable fairly well.
The end of the cable has to be pushed through it so that hasn't fallen off.
I think it fits on the larger of the rear door lower down on the inside, to prevent the wrong door being shut first. Apparently a few have come off. Sorry I don't have a photo but have seen pics
I think it fits on the larger of the rear door lower down on the inside, to prevent the wrong door being shut first. Apparently a few come off. Sorry I don't have a photo but have seen pics
The hole is were the holding nut has pulled through. Fix is to put a washer on first. If someone with a vehicle could photograph the rear large door near the bottom 1/3 you should see it fitted
