Weak AC, and a solution (HVAC reset via MUTE)
6:54 AM
Boulder, CO, USA
Well, I figured I would just leave a trail here for posterity. My Grenadier has been having an issue for a few weeks where even though it's a warm day, and it's very hot in the cabin, the auto mode barely blows the AC. If I do turn the temp control all the way to "LO" then, and only then, do the fans ramp and I get lots of cold air. If I turn it up one click--to 66F--the fan goes to super low speed and even though a bit of cool air is trickling out the vents, the interior is overheating.
So, I knew the system was physically working, and that it was some control problem. I tried a bunch of the tricks people mention about knob position, turning the car on slowly, etc. Nothing.
But, a simple 30sec press on the mute button (while the car was running) rebooted the infotainment controls and instantly the fans spooled up and the system is working again. I hadn't seen this mute trick mentioned except in one post by @Skydance so, thanks Skydance!
A complete reboot of the Head unit is also possible (not just HVAC).
Rok Dr Guide
so are you saying, the HVAC was working poorly consistently, across many driving sessions. Then you rebooted the infotainment system. Now it's all good across multiple drives?
