Weak AC, and a solution (HVAC reset via MUTE)
5:25 PM
Boulder, CO, USA
Well, I figured I would just leave a trail here for posterity. My Grenadier has been having an issue for a few weeks where even though it's a warm day, and it's very hot in the cabin, the auto mode barely blows the AC. If I do turn the temp control all the way to "LO" then, and only then, do the fans ramp and I get lots of cold air. If I turn it up one click--to 66F--the fan goes to super low speed and even though a bit of cool air is trickling out the vents, the interior is overheating.
So, I knew the system was physically working, and that it was some control problem. I tried a bunch of the tricks people mention about knob position, turning the car on slowly, etc. Nothing.
But, a simple 30sec press on the mute button (while the car was running) rebooted the infotainment controls and instantly the fans spooled up and the system is working again. I hadn't seen this mute trick mentioned except in one post by @Skydance so, thanks Skydance!
A complete reboot of the Head unit is also possible (not just HVAC).
Rok Dr Guide
Someone here pointed once that the exterior temperature is incorrect when the system isn’t functioning properly. I’ve found that to also be the case twice. I hypothesize the system is more complicated than it needs to be and is figuring outside temperature to blend with appropriate system temperature to reach desired results. A simple reset resulted in immediate properly functioning HVAC system twice. Perhaps the root of the issue is the exterior temperature sensor.🤷🤷
Actually the root cause is that the whole system is based on a X5.
A Google search will reveal X5 owners with exactly the same issues.
I couldn’t tell you if this is accurate or not but I also have a my25 x5 and it does from time to time have similar hvac issues on auto as my ineos. But then again the x5 everything is controlled by the infotainment screen and is over complicated to use with minimal physical buttons. I find myself just putting it into drive and not pressing anything anymore. Way to much technology in it.
My understanding is the Grenadier needs to read the outside temp when starting up.
I would suggest doing the recommended start up procedure of turning the key on without starting the engine.
When all of the lights have gone off, or stabilized, then start the engine.
As a matter of habit I turn off all the HVAC settings when I shutdown at night and I do the double remote lock button push.
I think this resets everything so it is ready for new settings in the morning.
These things have greatly reduce any issues with the HVAC.
Oh... I also kill a chicken 3 days after every full moon. But that is just for BBQ.
