Very annoying fan noise from level 4
MunichMax
7:39 PM
Hello everyone,
my Grenadier was once again at the service partner. The gearbox is leaking and the air conditioning is still a joke. The topic of the heating is already discussed in another thread, so that is not my point here.
Starting from fan level four, I get an almost unbearable high-pitched whirring noise. Up to level three the fans sound like normal fans. From level four onwards, an additional shrill whirring appears.
Here is a video of the noise and the difference between level 3 and level 4:
After asking the service partner to resolve the issue, I received the following answer:
“Dear Sir,
I wanted to inform you that your vehicle is ready for pickup. The heating is working again and regarding the whirring noise from the blower, this is normal. We also have customer vehicles where it whirrs on level 4 and INEOS confirmed that this is completely normal. It comes from the blower and does not indicate a defect.
Please note that our new service and sales location is in Germering in Industriestraße. The Baierbrunn location is no longer an INEOS Grenadier site.
Best regards,
Service Manager Ineos GRENΛDIER
Michael Schmidt Motor GmbH
Industriestraße 3
82110 Germering”
I have had this whirring noise since day one and it seems the service partner is unable to fix it. The statement that this is normal and that other vehicles have it as well is new to me.
I would now like to know your opinion: do you also have this noise at level 4? Is it really “normal”?
That is hard for me to believe, because in all vehicles I have owned so far, this would have been anything but normal.
Thanks in advance for your feedback and greetings from Munich.
I have the noise at level 4. Very high pitched and annoying. But I don't use heat much, only cooling. Mine is a very early edition. It doesn't do it unless it's a very hot day and the car had been totally in the sun. I got the same answer from service agent.
Thankfully it doesn't happen often
Same. I'm one of the blessed few with an MY23 and a fully functioning HVAC including auto mode. In auto the fan rarely spins up to 4 but it's got the same high pitch squeal.
Hello everyone,
“Dear Sir,
Best regards,
Industriestraße 3
82110 Germering”
Ahhhh Munich, wonderful town. Augustiner-Keller, Hirschgarten or Viktualienmarkt on a sunny day, paradise. No joy on fan setting 4, two and a bit years on and I still get the high pitched whine. First rule of Grenadier ownership, don’t use fan setting 4. Second rule of Grenadier ownership, don’t use Auto.
I get same noise.
What I've gathered there's "normal" and then there's "INEOS normal." The former is true, the latter is suspect.
I get same noise.
I love my Grenadier but this is hilarious... 2025 and an company tried to tell me that a noisy fan in an car is normal 🥳
Mine did make that whine, but having deliberately run it at full speed for an hour or so (with the radio turned up) it is far less noisy now.
The noise seems to be less when you have a clean and fresh filter. I wonder if the motor, at times, struggles to keep the pressure or overcome high pressure.
I found my fan whistled on setting no 1. No idea why 🤔😂😂
It’s Ineos normal. If you hit the demister button, the high frequency shrill exists. But I managed to shut it up once on a particular setting (I can’t remember exactly, ie to the feet only I think using fan 4). So basically it doesn’t make a noise if it blows into a path of least resistance. Is the fan not powerful enough under load, it produces this shriek or maybe it’s not earthed properly. Or could it be interference. Lots of questions.
HVAC issues are long in the tooth now. All the promises from Ineos, it won’t ever get fixed I think.
2025 Fieldmaster, 3 weeks old. On fan setting 5, there is a similar whirring sound - almost like bad bearings.
But that pales in noise comparison to the whistling that I get anytime the fan is on with air directed to the mid-level vents. If the vehicle is in motion (and only if), it whistles. The faster you go, the louder the whistle. Direct the air to any other vents, and the whistling stops.
I can't wait to hear if this is "normal" for these expensive vehicles. ;-)
Hello everyone,
“Dear Sir,
Best regards,
Industriestraße 3
82110 Germering”
Yes, my 23 Grenadier had the high pitch noise on fan setting 4 from day 1. I simply avoid using setting 4. Most of the time setting 2 does the job, occasionally I go to setting 3. I live in Queensland Australia so I only ever need cooling, usually set to 22 degrees.
Is fan setting 5 a MY2025 thing? (it’s a bit like having an amp that goes up to 11).
Yes the horrible noise on max fan is normal, very annoying (sounds more electrical in nature to me).
Oops - setting "MAX" which I guess would be 4. The "fifth" setting. Well you got what I meant... the Grenadier owners shorthand.
Noises like that aren't normal in vehicles half this price. Ineos should do their best to address it, if possible. Easy solution in the meantime is to not use max fan.
The fan in my 2022 build Grenadier has the same sound when set on 4. As I normally only use the „auto mode“, as it is the only way for me to get the heating/cooling system working in an appropriate way, the fans luckily do not run on 4 often.
I have the exact same behavior in my 2025
Apparently the new 2026 updates have eliminated this issue, hoping there's a retrofit they can do on prior model years
I just got mine back from service, during which I had a 2025 loaner. It had the same whistle. The dealer did not address it, claiming it has been declared as normal by Ineos Corp.
It’s not normal for a 2025 vehicles, much less a $90K+ vehicle.
No excuses. Fix this, Ineos.
