Suppliers ~ Cofle ~ Transfer case control linkage
5:53 AM
Cofle were named in the Supplier Bulletin for "shift lever and cables", so just a little more confirmation from the supplier itself who makes reference to "reduced gear arming and off-engagement systems and differential lock and release".
And a link to the article referenced:
So this company is responsible for the lockers? Or just the activation of said lockers?
I think they are Eaton Elockers on the Grenadier. Someone else will look it up quicker than me I guess
The bits you put your hand on in the cabin, right the way through to the two ball joints on the transfer case that make the changes internally for diff lock and high/low.
It's been commented on several times, in various forums that these linkages have been less than ideal, or troublesome.
As a rough approximation (in my mind's eye):
It's just dawned on me the length of the cables, especially the high/low range for a LHD. I wonder if RHD have significantly shorter, and perhaps more direct cable runs?
