Still can’t find it!!
Pannes
5:52 AM
Denver, CO, USA
Ok. I’ve been looking for the 10a under hood power supply for an hour. Two questions from a hapless new owner:
1) where the heck are the power supply wires? I’ve looked closely around, under and behind the positive battery post extension and nothing.
2) does anyone know if this (when I locate ) is prepared to support two 2.8 amp (each) small cube lights daisy chained together planning to be mounted under front bumper? Will these work discreetly by using the toggle switch on the overhead panel or will they be dependent/connected to a high beam relay ?
Thanks for the help.
Disregard. I found it. Was looking on the side of the rhd not the US version. ….. Thanks anyway.
Still interested in question 2 below.
1) Download the Rok Dr Guide, print it out and keep it in the car. It answers Question 1 and 2, plus much much more. See Figure 9, No 10.
2) It is a 10 amp circuit using the EXT1 switch (Fuse FI28). Look at Table 2 in the Rok Dr Guide. Short answer, it should. EXT1 is independent of the high beam relay.
Other helpful links:
PLACE TO START FOR NEW OWNERS
  1. Download and use the Rok Dr Guide here. Print out a copy and keep it in the car;
  2. Grenadier Accessories (huge selection) for you to buy here;
  3. Kanvas bags and products here;
  4. Information concerning Deutsch DTP plugs here;
  5. Learn more about the CTEK SMARTPASS 120S and 250SE here;
  6. Fuse and relay thread here;
  7. Suggested Grenadier or QM fuses spares kit here;
  8. Littelfuse FHZ busbars used in the Grenadier here. It also informs you where all the busbar cables go;
  9. Finding the aux power outlets in the footwells here;
  10. Table describing all the available wire ends here (more wire ends if you selected the high aux power option);
  11. Various recommended torque settings here;
  12. Tool kits for the Grenadier/QM discussed here and here;
  13. L track information here;
  14. Oil filter part numbers and third party filters here;
  15. INEOS Air filter parts numbers and cabin filter here;
  16. Filter for Diesel water separator here;
  17. Understanding the NATO plug on the Grenadier here;
  18. What do you use on bolts/screws to stop corrosion, galling and seizing here;
  19. Guide to terminal crimping here;
  20. Anderson plug pitfalls here;
  21. Outback driving tips here; and
  22. Cheap battery monitors here.
INSTALLATION (OR HOW TO) GUIDES
  1. SEAT COVERS: Canny Outdoors video fitting seat covers here;
  2. SPOT LIGHT REPLACEMENTS: Mounting Kit of Exezit Lights here and KC Hilites here;
  3. SIDE MIRRORS: Installing SUMA Performance side mirrors here;
  4. WORKLIGHTS: XHQ Work light here, with installation instructions here, STEDI Work light here and here;
  5. RETROFITTING A RED WINCH: Installation guide here;
  6. REAR ROOF SHELF: Canny Outdoors video installing KAON rear roof shelf here and a Travel Buddy oven fitted to a rear shelf here;
  7. ROCK SLIDERS (ABNTR4X4): Installation video for ABNTR4x4 Rock Sliders here, with suggested improvements for tougher environments here;
  8. ROO BAR: Installing the Roo Bar here;
  9. ROO BAR LED LIGHTBAR: Installing a 20 inch Lightforce Viper lightbar under the Roo Bar Hoop here;
  10. UHF (CB) RADIO: How to install a UHF (CB) Radio in an INEOS Grenadier without drilling any holes here;
  11. UNDER-BODY ARMOR (RIVAL): Installing Rival under-body armor here;
  12. UNDER-BODY ARMOR (CUSTOM OFFROAD) BASH PLATES: The installation thread is here;
  13. UNDER-BODY ARMOR (CUSTOM OFFROAD DIFF PROTECTORS): Installing the diff protectors and trailing arm protectors is here and the PDF here;
  14. UNDER-BODY ARMOR (ERO FLO FUEL FILTER GUARD): The installation thread is here and the PDF here;
  15. SIDE STEPS: Electric side steps installation guide here;
  16. INSTALLING AFTERMARKET SPEAKERS IN FRONT DOORS: instructions here, German language install here;
  17. INSTALLING BLACK SHEEP NUMBER PLATE HOLDER (US/AU models with OEM winches) here;
  18. INSTALLING REDARC TowPro Elite3: look here;
  19. INSTALLING THE WOLF G900 DASHCAM: Loc Nar's detailed installation guide here;
  20. B PILLAR (DISASSEMBLING): look here with detailed instructions here;
  21. INGEMAR’S GRENADIER HOW TO SERIES here and here (e.g winching, offroad modes, diffs, etc);
  22. INEOS FORUM resources here;
  23. INEOS Fitting Guides here, at least 9 guides from INEOS and Rhino Rack.
Regarding your second question. Yes the outlet should support the proposed lights as total amp draw will be < 10amps. This circuit is independent of the high beam circuit,. This may not be legal for forward facing lights in your part of the world so you may need to do additional wiring so the lights can only be switched on when high beam is activated.
Thanks so much for the reply.
Excellent. Sincere thanks for the information. Very helpful
I still cannot find the 25A high load Ext5 under the bonnet, RHD version. I have one, next to the air filter, but not the other one. Anyone have a close up photo showing both, by any chance? Need to wire in my spotlights in about 4 hours before Anzac weekend trip.
Also, how hard is it to remove the headlight to tap into the high beam wire?
Info in Rok Dr Guide here.
Do you have the high aux power option fitted? The IG only has two power circuits (wire ends) under the bonnet with the high power aux option fitted. EXT1 is standard and EXT5 is optional.
If fitted, the second set of wire ends (EXT5) should be close to the ones you have already found (EXT1), near the air box in a RHD car. See Figure 8 in Rok Dr Guide. In my car the two wire sets were taped together (ie EXT5 and EXT1). If you have the hi load aux power option look under the wires around the other wire ends, they can sometimes be hidden by the wiring loom. Look for the black plastic tape they use to keep them in place.
Easy to tell if you have the optional high power aux option, you have Switches EXT2, EXT3, EXT4 and EXT5 on the overhead console.
Yes, I have the high load option. I’ll have another look. Good to know they may be taped together.
Look under or behind the wiring loom, that is where mine were. Maybe taped under it.
Easiest is to look for the shiny black tape holding the wires ends to the loom and then explore around it.
On US vehicles the wires (EXT1 and EXT5) where further apart than on my car. They are also in a different position for LHD cars. So start searching around the existing wires you have found.
Pictures from another AU Spec car can be viewed here (I think the airbox has been removed in those images): https://www.theineosforum.com/threa...uxiliary-power-point.12412953/post-1333221402
img_3201-jpg.7829858
img_3202-jpg.7829859
I do not have the high amp option. I'm thinking of adding some switches of my own to the empty panel, Has anyone located a similar switch? Amazon Switch
I plan to make each of my switches 26A plus one that will be
You could do a set like agile. They put switch pro with a believe a crerebo in roof. The sell the holder.
If you search under "Rocker Switch" you may find more choices, if that is what you want. EDIT: you can get Carling Tech switches here. I remembered rocker switches are sometimes called Carling Switches.
I can give you Australian links for ideas.
SWITCHES, SWITCH PANELS, HOUSINGS, ETC.
Many of switches seen on 4X4s are Carling type switches (now owned by Littelfuse) also called rocker switches. Australian sources of these switches include:
  1. Lightforce, which has an extensive range of switches and switch panels, including custom printed switches, switch fascias (panels), USB chargers, UHF passthroughs, etc;
  2. SAAS, which has an extensive range of switches and switch panels, especially Carling Panels;
  3. Kenay Kustoms switches and switch panels here;
  4. STEDI, which has an extensive range of switches and panels;
  5. Baintech, rocker switch panels;
  6. Enerdrive, water resistant rocker switches. Which I think are made by Blueseas Systems who also make Condura Switches, Toggle Switches, Rocker Switches and Rotary Switches;
  7. Brown Davis DYI powerboard;
  8. HULK connectors, panels and housings. Also switch panels;
  9. DRIFTA Stockton Control Box, Mini Power Box and Distribution Panel;
  10. Some upmarket switches from the US here;
  11. Narva, with both switches and panels, like Sealed LED rocker switches, OEM styles switches, Toggle Switches and more; and
  12. Specialist panels like Razed Products panel for your air compressor switch and outlet, UHF pass through adapter by GME, etc.
I'd like to put a light bar on but I'm not entirely sure how or where to find a feed from the high beams. I think this is required in Australia so the light bar won't work unless the high beam lights are on. I was hoping to just use a fuse tap somewhere but I doubt that's going to be possible.
I'm mounting a switch-pros thing under the seat in that space behind the auxiliary battery. The switch-pros needs an ignition signal connection. Is there somewhere under the seat that I can use for an ignition signal or should I go to the fuse panel by the steering wheel and use a fuse tap in FC14 (Ignition switch / steering wheel)?
Should I connect the positive connection on the switch-pros to the main battery or to the auxiliary battery? From what I've read in Rok Dr Guide, I'm going to guess it should be connected to the main battery and not the auxiliary batter.
Regarding the light bar Stedi make a plug and play loom at a reasonable price which may solve your problems. https://www.stedi.com.au/dual-connector-plug-play-smart-harnesstm-to-suit-ineos-grenadier.html.
As for an under seat ignition signal for my third battery box DCDC solution I used a fuse tap off the power mirror fuse in the under seat fuse box. See this post for a pic. https://www.theineosforum.com/threads/henrys-blog.12414322/page-6#post-1333325924
Finally I’m not familiar with the switch pro system but if you are planning on keeping the dual battery system standard then drawing off the main battery is best. That said if the loads you are drawing through the switch pro system are high and continuous then you may need to refit the standard battery system to cope and I’d recommend consulting a good auto electrician in that case.
Cheers
Steve
1. One posibility is a Lightforce 20 inch Viper lightbar install here. There is a relay connected to the OEM driving lights so the Viper can only come on when highbeams engaged. Lightbar must be under the hoop in NSW and WA. Lots more detail in the link, with install steps. There is also a thread with different Lightbars I will try an find.
2. Wire ends under the seat has an ignition source. Lots of detail here (download PDF on top right).
3. I connected some of my accessories off the aux battery, one reason is because I have a solar panel on the roof, which charges the aux battery first (setup is CTEK120S and CTEK250SE).
Some other links that may come in handy, like Items 4 to 10 in the first list. Updated list from above.
  10. Table describing all the available wire ends here and here (more wire ends if you selected the high aux power option);
  11. Various recommended torque settings here and here (with Torque Table). General torque values (not INEOS specific) here;
  19. Grenadier Fluid Specifications PDF download here;
  20. B58 Engine Reference Manual here;
  21. Guide to terminal crimping here;
  22. Anderson plug pitfalls here;
  23. Outback driving tips here; and
  24. Cheap battery monitors here.
  2. SPOT LIGHT REPLACEMENTS: Mounting Kit of Exezit Lights here and KC Hilites here (new Laser Lamps Kit also announced);
  6. RETROFITTING 300W INVERTER look here. Thanks @landmannnn;
  7. REAR ROOF SHELF: Canny Outdoors video installing KAON rear roof shelf here and a Travel Buddy oven fitted to a rear shelf here;
  8. ROCK SLIDERS (ABNTR4X4): Installation video for ABNTR4x4 Rock Sliders here, with suggested improvements for tougher environments here;
  9. ROO BAR: Installing the Roo Bar here;
  10. ROO BAR LED LIGHTBAR: Installing a 20 inch Lightforce Viper lightbar under the Roo Bar Hoop here;
  11. UHF (CB) RADIO: How to install a UHF (CB) Radio in an INEOS Grenadier without drilling any holes here;
  12. UNDER-BODY ARMOR (RIVAL): Installing Rival under-body armor here;
  13. UNDER-BODY ARMOR (CUSTOM OFFROAD) BASH PLATES: The installation thread is here;
  14. UNDER-BODY ARMOR (CUSTOM OFFROAD DIFF PROTECTORS): Installing the diff protectors and trailing arm protectors is here and the PDF here;
  15. UNDER-BODY ARMOR (ERO FLO FUEL FILTER GUARD): The installation thread is here and the PDF here;
  16. SIDE STEPS: Electric side steps installation guide here;
  17. INSTALLING AFTERMARKET SPEAKERS IN FRONT DOORS: instructions here, German language install here;
  18. INSTALLING BLACK SHEEP NUMBER PLATE HOLDER (US/AU models with OEM winches) here;
  19. INSTALLING REDARC TowPro Elite3: look here;
  20. INSTALLING THE WOLF G900 DASHCAM: Loc Nar's detailed installation guide here;
  21. B PILLAR (DISASSEMBLING): look here with detailed instructions here;
  22. REMOVE RAISED INTAKE and replace with grille here;
  23. INGEMAR’S GRENADIER HOW TO SERIES here and here (e.g winching, offroad modes, diffs, etc);
  24. INEOS FORUM resources here;
  25. INEOS Fitting Guides here, at least 9 guides from INEOS and Rhino Rack.
I found the yellow ignition source wire under the seat. Thank you! Next problem, from what you mentioned about the placement of the light bar. That means the 30" light bar I bought from Expedition HQ, which they show mounted to the top of the bull bar is illegal in NSW and WA?
https://expeditionhq.com.au/product/narva-ex2-30-double-row-light-bar-with-ineos-grenadier-mounting-brackets/
https://expeditionhq.com.au/product...t-bar-with-ineos-grenadier-mounting-brackets/
I have seen plenty of them mounted above the roo bar in NSW. I think it is an interpretation point. NSW and WA seem to have a different interpretation of the standard to the other states.
I have heard it argued such a lightbar it can impede forward vision as well. Same ADR standard, different interpretations. Attached is NSW document on the subject.
This is what NARVA says for NSW (NARVA evens says it is not OK above the bar in QLD 🤪):
Mines in line with the top bar, in front, but not protruding beyond the bumper.
If that’s not legal, they can hunt me down and spank me.
