Sprinter van wheel
TheGoodHeartedgreen
7:44 AM
Dallas Texas
Can anyone confirm that the sprinter van wheel hub flange is the same diameter as the Grenadier. I want to keep the steelies but want to utilize a slip over hub spacer that rides over the hub like what OWL has for the sprinter vans. Its a much safer option than a bolt on spacer. I dont want much extra width, would just like them to be not so tucked.
Thanks in advance.
Thanks in advance.
The Grenadier hub pilot diameter is 130mm. The newer Sprinter vans (VS30) use a 120mm hub. They are not the same.
You cannot use a Sprinter-specific hub-centric spacer on a Grenadier. You will need to find a spacer specifically made for the Grenadier's 130mm hub and 6x130 bolt pattern.
Good Rob clarified! I have a 4x4 Sprinter, I was going to try a swap!
Yes, the 6-lug Sprinter wheel has the same hub diameter and bolt pattern. It is 6.5" wide, narrower than the Grenadier's 17" steelies.
You will need 6mm or 1/4" thick spacer to clear the brake calipers - the wheels have deeper offset. You will also need domed (not cone) lug nuts, Porsche style.
Amazon has them.
