Rubber smell
Oakbluff
12:21 AM
Atlanta
I smell a rubber burning smell after I turn Grenadier off and get out.
The is no noise, sounds or malfunctions?
Pls give me some thoughts what it could be anyone.
Is it lifted? If so check the rubber boots on the drive shafts.
Maybe some underbody protection oil on/near the exhaust?
Thanks, I will look underneath tomorrow to see if there any signs of fluid or discoloration.
Normally only a diesel model issue but pop off the plastic engine cover and check the rear corners & lip are not melting.
Check for oil leaking onto exhaust below turbo. I thought it was a rubber smell too until I opened the bonnet and saw the smoke.
I was going to say that too. I have a leaky turbo oil pipe. I did notice a burning rubber smell a few days ago. I now think that was the oil leak.
Both of these are on B58s or B57s?
Check for the timing belt touching something which isn't properly installed/mounted/seating.
Some times new cars will have some sort of off gassing, Also new tires when nice and HOT tend to smell a bit.
