Release - GP Factor Diesel Heater Kit for Station Wagons
GPFACTOR
Supporting Vendor
5:50 PM
United States
Good Morning Grenadier Fam! In case you did not see the post in our vendor forum area. We are excited to announce the launch of our GP Jetpack Diesel Heater Kit for the Grenadiers! Pre-Orders are open now and first batch will be shipping end of December. Details are below but here are a few easy answers to common questions:
1. Kit comes with the Webasto Airtop STC2000 3.0 Bluetooth Heater Full Kit
2. Kit includes all the parts needed to install less any extra wire length needed to power if you are not going to your under seat batteries
3. Fuel tank included
4. Yes, this removes that small rear window and seals in that spot the same as a window would. We recommend having a qualified shop remove your window for you. We had ours removed for 50.00 by a body shop so its not costly or time consuming.
5. Kits will require assembly of the Webasto parts in the kit pieces. Detailed instructions will be released closer to shipping date in December. Its not difficult. Just wanted everyone to be aware
6. Kits will come with the Webasto only. Its a solid reliable heater so we didn't want to pair a kit like this with the knock off heaters that brake alot easier.
7. Outside and inside panels are completely removable for easy maintenance of the heater when needed.
Let me know if you have any questions. Cheers!
INFO: https://gp-factor.com/products/ineo...esel-heater-kit-w-webasto-airtop-stc-2000-3-0
Turn your Grenadier into a true four-season adventure rig.
GP Factor proudly introduces the first product in its new GP Jetpack line of vehicle heater systems — the GP Jetpack Heater Kit for the Ineos Grenadier Station Wagon. Designed for seamless integration, this turnkey system allows you to install a thermostat-controlled, diesel-fueled Webasto Airtop STC 2000 Bluetooth 3.0 heater without compromising your vehicle’s rugged aesthetics or cargo space.
Precision-engineered to fit directly into the Grenadier’s rear door, the GP Jetpack system follows the vehicle’s natural lines, maintaining a clean and compact profile. Despite its low-profile design, it delivers exceptional heat output — perfect for keeping you warm through long, cold nights off-grid.
Each kit includes a removable interior vent panel and exterior service cover for easy access and maintenance. The system is built to recirculate cabin air, maximizing both heating efficiency and fuel economy — so you stay comfortable while conserving energy.
  • Fuel Tank – 3.3-gallon diesel tank with a vented Radium Engineering fuel cell cap.
  • Heater Unit – Genuine Webasto Airtop STC 2000 Bluetooth 3.0 heater and all required accessories.
  • Finish – Durable black textured powder coat exterior, with a gray powder-coated interior vent panel.
  • Mounting Hardware – Custom bracket for internal fuel pump mounting, all fuel lines, and a starter electrical harness for easy vehicle connection.
Engineered for reliability, efficiency, and seamless integration, the GP Jetpack Heater Kit is the ultimate upgrade for transforming your Ineos Grenadier into a year-round exploration machine.
That’s a very neat solution and easy to install. Do you have a UK distributor for your products? Purchasing directly from yourselves would be very costly I guess with shipping and import duties?
Someone's HVAC is working 🤣
Looks A great product 👌
I have had Wallas heaters on our boat. We were up in Canada a couple of years ago for Christmas/New Years. We were sweating in shorts before we figured out the thermostat. Granted we had the 4.5KW furnace and the 2kw cooktop in a 28 foot boat.
Pretty sure Buzz Overland should be the go to for GP Factor in the UK, after chating with both AJ (of GP-Factor) and Alex (of Buzz) back in July.
