Protective armor and drivetrain temperatures
pmatusov
6:35 PM
San Diego, CA, USA
After hearing the driveshaft horror stories, I populated my Gren's toolbox with an IR gun. The CV joints at either driveshaft didn't reveal anything out of ordinary.
Last Saturday I had several extended SoCal highway runs - with air temperature around 75F and typical I-5 speeds. I got under and hit the centers of the diff covers with the IR gun: the front read between 50 and 55C (122-131F), but the rear - 80 to 83C (176-181F). None are a cause for any concern, but a 30C (55F) difference is unexpected. I could speculate that the front diff is exposed to ambient air and rear - to the warm wash from the transmission, transfer case, and immediate muffler vicinity. Still, 30C is a big step.
The only other difference is the skidplate under the rear diff. I will take it off for a highway drive just to see if it makes any difference - post the results when that happens.
Whatever the cause is, I need to revisit my maintenance schedule. Changed the oil in the rear diff (first change - 12k, now 46k) - oil came out clean, no iron shavings on the plug.
I'll probably punch a few 1-2" holes in the transmission skidplate as well.
You could fabricate a diffuser or add a fan 🤓 I suspect it won't make much
diff-errence, but who knows?
Typically, my transmission and t-case temperatures are 169F (76C) and 130-140F (55-60C). They haven't changed at all since I fabbed the transmission skidplate, so I am not _that_ worried about it.
Trans skid plate details? I need to do this…
I'll get them next time I take it out. But... basically, a sheet of 6061, 0.109" thick, cut in the rear to conform to the contour of the transfer case crossmember. Three bolts holding the rear of the plate to the crossmember, and two steel angles holding the front to the frame brackets.
Since the piece of 6061 I had was so thin, I bolted a 3/4" square bar to the front of it to increase stiffness.
Next time I'll make one out of 1/4" Aluminum, with proper bends for the front support and upward 45-degree bent lip in the front of the transmission.
