Pics of 1.7" Eibach kit
Here you go. I had the 1.7" front springs installed today. I have held off on getting the rear 1.2" springs installed as I really wanted to eliminate the 2+" rake that the truck had in stock form. I love how it sits with just the front 1.7".
Eibach says they will soon be offering front and rear springs separately. Interestingly, they no longer offer the 2.5"/1.2" kit. Possibly due to some issues with the front driveshaft.
I parked next to a buddy's stock Trialmaster for comparison.
I ended up going with the 1.7" front + 1.2" rear and love it. I like a bit of rake, and with the fox dampener, it drives fantastic on 34x10.5r17 Toyo at3s. Seems like a smart move with the issues the 2.5" has had. Appreciate all the input!
I'm thinking about doing the 1.7" + 1.2" combo
What size tire can you fit with that combo?
I have 33" tires on my stock truck without any problems
Same as stock, 35s; I'm moderately confident that going to 37s will require fender (or at least flare) modifications)
Reviving the thread now I see there are more of us migrating to the 1.7 front and 1.2 rear from the 2.5/1.2. I’m still on 285/70/17 MT Baja Boss AT’s for now; likely going to 305 or 315 soon.
Just food for thought, in case anyone was curious as to what they’re getting into.
I've never levelled up a vehicle's factory rake. Is it just a cosmetic thing? Do you guys find any change in steering/ corner handling or hard braking?
I've been reluctant to level it because I feel like the rake actually results in better visibility on the trail. I could be over-stating that, though.
Because removing rake is as American as apple pie. 😆
But in my pilot’s mind, I would imagine removing some rake helps some aerodynamic drag along the roof line.
But if you raised the front by 4", imagine the rock step you could conquer!
A truly American trend... In my opinion, it is founded in the fact that we as a country love to buy vehicles and not use them for their purpose... Like buying 1 ton pickups and never putting anything in the bed; enter the "leveling kit". This could easily be avoided if you carried anywhere close to the 1800kg payload in the bed of those trucks
But much better than this trend 😀
I just did this. The 1.7 fronts and 1.2 rears.
Stock 17” steel wheels.
Easily fit 285/75/17 KM3’s.
Could have fit 35x12.5x17 with minimal plastic trimming. Didn’t want to do bigger offset wheels, likely would fit then. Also unsure of the articulation range but the 35 didn’t look like it was “stuffed” up in there.
Happy with my outcome, I tow a lot and had to retain the rake so I wasn’t Carolina squatting.
Thanks for this. I've been on the fence of 305's vs 315 70/17's Thinking I'll go 315 now.
Anyone else out there do a 1.7 - 1.2 lift with 35x12.5 17's? Any rubbing??? photos?
In addition to all the fun glamour shots of various suspension lifts what would be equally helpful would be before and after pictures which include detailed shots of the driveshaft angles. This could help us build a visual database of how those are impacted with each lift so folks can make informed decisions if they are concerned about driveshaft longevity.
