Overcurrent Warning Using MagSafe Charger in Center Console USB-C
c00kedg00se
11:22 PM
Boise, ID
Hey all,
I’ve got a 2025 Grenadier and ran into an odd issue: plugging my Apple MagSafe charger into the center console USB-C port triggers an overcurrent warning. But it works perfectly with the rear USB-C port.
No signs of damage, and the cable works fine elsewhere. Has anyone seen this? Could it be a firmware thing or just a limitation of that port?
Appreciate any insight or fixes you’ve found!
I had a similar warning a few times for the USB outlets in the cubby-box when I had my Android phone connected to them. But I didn't care and there was no further damage except that this message occurred a few more times. There is no such message if I charge my phone from the rear passenger outlets (in the middle in front of the rear seat-row).
The ports in the centre console have a charging limit of 1.5 Amps and support USB2.0 data transfer speeds.
The optional USB ports installed on the rear of the centre console are for charging only, they have no data functionality. The USB A port has a 2.4-amp output. The USB C port has a 3-amp output.
Cheers
Steve
Cheers
Steve
Thanks Steve
