Off-Roading Fail I Wish I Saw Coming – Sharing in Case It Helps Someone
DVA Mechanics
Supporting Vendor
9:13 PM
Atlanta, GA, USA
Figured I’d share this to save someone else the headache - even though I’m definitely cringing while typing it.
We went out to film some social content and figured we’d grab a shot of the traction boards in action. Looked shallow enough. Spoiler: it wasn’t. The vehicle ended up sitting in mud for hours before we could get it out. Water made its way in—and the rear fuse box got soaked.
The car started right during recovery, but about three hours later (after a half-hearted field-drying attempt), it stopped cranking altogether.
Aftermath?
  • Deep cleaning
  • Electrical treatment
  • Fuse replacements
  • Dealership visit, of course.
And two weeks later, the drivers door stopped locking. Still not fixed.
Moral of the story:
Shooting content pushes you to learn something new every day—but sometimes it teaches you the hard way.
Always assume it’s deeper than it looks. Use a damn depth stick. It’ll save you a lot of time, money, and headaches.
Stay safe out there, mud warriors.
I would have not expected that this kills the capability to drive on, I mean it is a tough offroad vehicle. Dirt, ok, fine. Not nice, but you can get rid of it (almost). Got stuck, fine, you can pull it out. But that much ECU failures...huh.. I mean, it doesn't look so bad, only one side partly in mud.
That's why I love really simple cars. Unfortunately....gone...forever...
View: https://youtu.be/mysp9FeOfd8?si=lCG-xwv-1mgUMR8Z
That's a good one. Fell over 90 degrees in mud...but continues after a check.
View: https://youtu.be/940gq5K0To4?si=7y5hR69ZQWBPwJ7l
Even better, very calm, nice stroll...
View: https://youtu.be/qr8eEWyKQHM?si=NeHUaXekqHDJ6wo3
Even a Td5 with ECU is capable of...
View: https://youtu.be/53PumbeAImI?si=1Qeo3l9EaLlpi95Q
Ouch! 🫣 PADI or C.M.A.S.? Will the lights pass the next technical inspection (MOT)?
You're right. That applies to all cars. The fine sand in the mud is very bad. That's why I stopped doing such stuff just for fun, as it costs a lot of money and time to get things nice again, after you took such a drive. However, the cars did it, no question, the are able to drive on, but they need some caresses after.
Thanks for sharing. We get the gain without the pain.
Look on the brighter side, it was not the side with the air intake for the motor. You can take out the floor plugs and hose it out.
Or worse, drive flat, flood transmission intake and get water in all my diffs too
All of those codes must be coming from one of the wheel speed sensors. A tradeoff of having a modern car
I didn't mention, the guy decided to drive home after boating his L200.
It didn't make it. Gearbox and rear differential completely destroyed. Oil and water definitely do mix and don't lubricate.
Bugger!
Looks like sideways assist can't do it alone!
