No power to auxiliary plugs ext 2 and ext 3
doonunit
Quartermaster Owner
9:01 PM
Australia
Just got a new light to mount on the roof of my grenadier. Plugged it in and no light… No power to the DTP plugs on either side or the fuses. All fuses have continuity. I’ve tried with the key off, aux power switch on and both ext switches on + I’ve tried the same with the key on. No change.
I’ve got a camping trip in 2 days so I’m in a bit of a pickle. Can anyone help? It’s gotta be something simple…
If you found the fuses you probably found the relays but check this fuses and relays post.
Post in thread 'Main fuses used in INEOS Grenadier' https://www.theineosforum.com/threads/main-fuses-used-in-ineos-grenadier.12411958/post-1333181794
Thanks mate, I checked all those fuses but I didn’t test the relays, good idea. Just had a listen then, the power relay is audibly activating, but I can’t hear a relay clicking from any of the other ext switches. Ext 1 activates a fog light function on my aftermarket spotlights, it works fine. No audible click from that relay either but still works.
I will test the relays tomorrow.
