New suspension
4:46 AM
Florida, USA
Just wanted to put this option out there for anyone wanting to lift the Grenny.
Mega shout out to Shadowmarq for getting these parts and helping to develop along with King what I think is so far the best option for lifting. Here is the part list.
1. King-grenadier-2-5-front-kit-with-compression-adjuster
2 King 1.5 Springs
3. Metalcloke adjustable linkages
4. Rotora extended brake lines
5. Black Rhino Stadium 17x8 38offset
6. BF Goodrich KO2 35x12
With the metal cloak and the springs being slightly shorter than the Eibach springs I have been really happy with the ride quality, the amount of travel and the angle of the driveshaft while still being able to stuff 35s at full lock.
Other parts
GP Factor Bull Bar
Dissent Offroad rock sliders
Trailrax 3/4 roofrack
Expel Stealth PPF
Agile Offroad tire relocation kit.
shadowmarq.com
So what we all want to know is how do the "Kings" ride???
The combo of spring and shocks is a softer and more comfortable on the road. If you think the stock suspension is too stiff I would definitely say it’s an improvement . I will say I have a little more body roll in the corners so I am going to try and adjust the shocks a little stiffer but it is probably perfect for off-road how it’s set up now.
That is very impressive. Can't wait to hear how it performs off road!
I am trying to decide about a lift and tires. There is talk of Angles being too much and failures of axle or CV? I forget at the moment. It would be nice to know what the limits are. The stock clearance is a bit low.
Also what about the gearing? Do you feel it is OK with 35" tires?
The engine seems to have plenty of torque I don’t feel like there is enough performance loss to matter. I did a Bronco lift to 37’s on their turbo V6 and it felt more significant.
Were you able to dial in the body roll? And how comfortable are expansion joints, pot holes and small road imperfections? Does the adjuster have an effect on those?
I added two clicks of stiffness to the kings and am very happy with the on-road feel. It is soft enough to be comfortable but with less body roll around corners. It is amazing how easy it is to adjust. It takes 30 seconds to walk around and dial it in.
